Rear Windshield Issue
Old Nov 13, 2010 | 10:50 AM
phatboyfromla's Avatar
Default Rear Power Windshield Issue
The passenger side of the rear windshield is stuck. The driver's side can move freely but I can't put it up of course because the passenger's side is stuck in the down position. I pulled the panel off the back of the windshield and it looks like the belt that drives the large window "screw" is completed rotted as you can see in the pic. Now how do you expose the top of each side to insert a new belt?
Also, I looked in the small cutout space behind the passenger's seat while the top was up and saw these two connectors. One looks like an antenna cable and the other some type of computer connection. Are these supposed to be connected to something? TIA
Attached Thumbnails Rear Windshield Issue-belt.jpg   Rear Windshield Issue-wires.jpg
Old Nov 13, 2010 | 10:09 PM
Default Rear windshield iisue
Well I cut the old belt off. It looks like there might be enough room to slip the new belt over the top of the gear. More clearance on the passenger's side. We'll see.
Old Jun 28, 2011 | 10:19 PM
thejaycan's Avatar
Well, this thread is a bit old but I figured I'd give it a shot.
I also have the same problem with my 2001 TT's rear windshield. I was wondering if you were able to get a new belt on there. And did you buy the belt from the dealer?
Regarding the connectors, I believe the antenna port and the db connector are used if you have on-board navigation. I don't have it in my TT so mine looks like your picture.
-J
Old Jul 4, 2013 | 07:06 AM
lreperro's Avatar
Default 2002 Audi tt windscreen belt
I found the belt broken on my windscreen, work in automation we use these belts on servo drives, ordered a new one for $28.00 much better quality belt than original its a dayco worked great
Old Aug 10, 2013 | 12:13 PM
ken.voisine's Avatar
lreperro, I'm facing the same issue with my 2001 TTQR, could you provide the dayco part number?
Kind Regards
ken
SVT21
Mar 30, 2011 01:43 PM
evan671
Dec 11, 2009 08:06 AM
koston33
Aug 9, 2009 07:20 PM
koston33
B7 Models
Jul 23, 2009 11:15 AM
hboost
Jul 2, 2008 06:45 PM
