Removing Manifold / Turbo
Old May 29, 2011 | 01:30 PM
prsalmon's Avatar
Default Removing Manifold / Turbo
Hi. I discovered that the gasket between my Exhaust manifold and Turbo had blown, so removed the old one and replaced only to find that it still blew with the new one in place. I removed the 3 bolts again to check / re-seat the gasket and one of the bolts sheared off!! Because of the shape of the left over bolt i dont want to drill it incase of further damage. How do i remove the turbo unit / manifold to get to the bolt remnants?
Old May 31, 2011 | 06:29 PM
cincyTT's Avatar
I'm make believe
Drain the fluids, unbolt the manifold, tip, and bolt under the turbo, and it will come out the top as a whole. It will also be easier if you remove the valve cover so you have more space. I fit my pagparts manifold and much larger turbo in this way without issue.
DraxeofDclan
May 7, 2013 09:29 PM
Expplucky
Apr 24, 2013 03:11 PM
02AudiA63L_65
Aug 21, 2010 10:57 AM
mikekey
Apr 29, 2010 11:11 AM
lehighwiz
Jun 1, 2007 09:52 AM
