reward if you can diagnose my rough TT
Maybe I'm thinking a little too simply here but I know when mine started to do the same thing, it was because 100,000 miles of gas had been filtered through the same factory fuel filter (dealership never changed it) so, upon changing that it came right back to health. Usually fuel problems don't throw any sort of CEL, as far as I know...but then again, I am still a noob to the TT family and am trying to stay in my lane.
I will try that sea foam trick tonight, sounds like fun.
also, the problem is there when the car isn't moving. I can sit in the driveway and get the problem. Doesn't matter if clutch is in or out, or if I am in gear or not. moving or stand still, no diffference.
love it
love it
All these things are just speculation and impossible to say what it is for sure with out directly looking at your car. If you can get Vagcom that would be ideal, if not take it to someone who has one. I am all about doing my own work to my car and utilizing forums for answers but not to be rude but it sounds like you really have no clue so you should either take it some where that is VW/Audi certified or get the correct tools.
You are right, I am out of answers. I'll get the VAG-com and take time to get educated on it. Or move to a town with a mechanic that will work on the car. I like wrenching and all, but there is a time when a pro needs to step in!
PS
PS
also if you do the seafoam your plugs might* go bad some report plugs going bad after running it through the vac system....i know it fouled my plugs after i seafoamed my 92 ford ranger truck(winter beater) so beware....idea! take a video of your car and post it on youtube...if we can hear the problem that would help....also im think of possible n75,SAI,EGR and even 02 sensors here
I was going to just replace the o2 sensors until I saw what they cost! That is the point I decided to quite just throwing money at it.
The TT has started to suck money from wallet when I just walk past it now.
I did drive it to work today and will try and beg the VW dealer to look at it. They seem pretty busy fixing their own problem car
I have a honda element and that dealership service is never busy.
hmm, just a thought but i believe you said you had your engine mounts replaced, did you put OEM ones back in? because i think there is a little bit of rough"ness" with the VF engineering ones, i could be mistaken though
