rim fitment question 4762
Old May 15, 2008 | 09:05 AM
randomloginname's Avatar
Default rim fitment question 4762
Okay, looking at a forum members et20 18x8.5 5x100 rs4 reps, I checked on the calculator and it said 2mm poke up front and 4mm inside fender rear, does that mean I cant use them because theywill rub up front? thanks..... oh the tires are 215/40/18
Old May 15, 2008 | 09:31 AM
beachchair's Avatar
Default RE: rim fitment question 4762
ORIGINAL: randomloginname
This does seem to be wheel question week.
I did a lot of research before buying my wheels and was told the widest I could go up front was 8" with 225/45's. Offset 35mm. However, I have seen photos of TT's claiming to have 9.5's in the front. I don't know if that helps, or if being outside 2mm will cause a rub. 2mm is not much, and seems you may be able to make "adjustments" to your wheel wells if necessary. It would suck to buy new wheels and tires and have them rub.
Old May 15, 2008 | 12:26 PM
Old May 15, 2008 | 02:46 PM
Murderface's Avatar
You'll be fine. A little poke won't kill you...remember "if ya ain't rubbin ya ain't dubbin"
Matter of fact you're going to be close to the setup I'll be running...8.5" 19's ET35 front and rear with 15mm and 20mm spacers, respectively.
guitarrocker98
Oct 3, 2011 03:58 PM
joenelson7687
Sep 17, 2010 01:15 PM
RS808
Mar 3, 2010 04:39 PM
picco97
Jul 16, 2008 12:46 AM
remusa4
May 30, 2007 08:37 PM
