same code
Old Sep 18, 2008 | 10:28 PM
intake's Avatar
Default same code
A few months back i got code P0411 (Secondary Air Injection System: Incorrect Flow Detected),searched around and found a few cracked houses and replaced them. I did a resest and all was good for months but now code is back so searched hoses again and as i searched found a new problem , oil leaking from somewhere on passenger side of engine. Any ideas on both problems would be awesome!
Old Sep 19, 2008 | 12:48 AM
achTTung's Avatar
near the top of the engine, bottom, what? Could be valve cover gasket, could be cam seals, could be oil pan.
Old Sep 19, 2008 | 01:57 AM
GHETTOxWHITExBOY's Avatar
Is it the front passenger side ??? Could be a power steering leak. What color is the fluid ???
Old Sep 19, 2008 | 09:03 PM
intake's Avatar
It's the passenger side around the timing belt cover ,in that area. i took off the cover under the car when my p0411 code came back to look at more possible cracked hoses and seen oil on the cover and when i looked up. Wiped it all from underneath than took off the engine cover and the one covering the power steering and over flow bottles and seen oil on everything , i was low about a quart.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
