shaky boost needle
Old Jul 20, 2007 | 06:07 PM
ttfan13's Avatar
Default shaky boost needle
hey guys, hoping you wouldn't mind helping me out with this... my boost needle sometimes shakes violently under boost, and my car always (moreso lately] boosts to somewhere near where it should, and then slowly loses boost pressure. I want to get a boost machine, new turbo lines, and a new DV... oh, also bamm and 4.0 FPR.
I've got an intake and chip, exhaust/dp/cat bypass
help pls!!!! thanks again
Old Jul 20, 2007 | 06:12 PM
gravitt's Avatar
Default RE: shaky boost needle
The needle will shake a little, normally, but you may want to double check the fitment of the lines from the gauge to the FPR.
What do you mean you have a cat bypass. Are you just using a testpipe?
Old Jul 20, 2007 | 06:15 PM
theTTkid's Avatar
make sure all your connections are good....
also, your boost should also start to slowly tail off once you get to a certain point in the rpm range...
Old Jul 20, 2007 | 10:14 PM
andrei's Avatar
check the T on your gauge line... make sure the end with the little amber part is connected to the black hose originalygoing into the FPR, (you probably already knew that though)... if you have it set up like that..if not, i have no idea.
shockwavecs
Jun 7, 2010 09:57 AM
01A4CFF
Mar 3, 2010 09:03 PM
B5 owns
Aug 31, 2008 11:02 PM
socialdbob
Apr 30, 2007 09:18 PM
cinescapist
Feb 20, 2006 02:43 PM
