Shift knob stuck
Old Feb 4, 2009 | 11:49 PM
warranty225cpe's Avatar
Default Shift **** stuck
I'm trying to take off my shift ****. The entire shifter turns counter clockwise. I've had the **** off before, but I think I overtightened it. Was I suppose to push down when I turn? How the he'll is the shifter turning? This can't be good.
Old Feb 5, 2009 | 04:14 PM
Anyone...? buler?
Old Feb 5, 2009 | 05:36 PM
joshuo's Avatar
All i can think of is to loosen the big silver ring (black in your case).
Then you can lift it up, grab the shift rod with a vice grip, and thread the **** off.
Old Feb 5, 2009 | 05:41 PM
achTTung's Avatar
exactly. the shaft shouldn't move, get something on it so it stays put.
Old Feb 5, 2009 | 05:59 PM
I think im gonna use a pipe wrench. Im not looking forward to taking the shift ring off again tho. Its pretty tricky since i need to try not to scratch the new paint.
Old Feb 5, 2009 | 06:24 PM
myslow1's Avatar
you wouldnt have to worry about that if you didnt paint it
Old Feb 5, 2009 | 06:28 PM
achTTung's Avatar
or if you never reinstalled it to begin with.
Old Feb 5, 2009 | 06:32 PM
ninjatturtle's Avatar
Member
you could put a layer of electrical tape around it first. the tape will be sticky enough to transfer the force from the wrench and protect from scratching/marking.
Old Feb 5, 2009 | 07:30 PM
joshuo's Avatar
The wrench won't touch anything that can be seen...
Old Feb 5, 2009 | 07:44 PM
I agree. I think I just needs 2 sets of hands. 1 to hold the wrench tight, and 1 to crank the **** out of the shift ****.
