skid plate?
Old Feb 22, 2007 | 05:54 PM
Audi_droptop's Avatar
Default skid plate?
Hey... my brother is a machanic so i let him do my oil change for my 02 TT. he took off the plastic skid plate(i believe thats what its called)to drain the oil but did not place it back on correctly... the plate got damaged as i was driving... now it wont snap back on... my question is,do i need it? what is it's purpose? if i need to buy another one where can i get one and for how much? Thanks!
Old Feb 22, 2007 | 06:32 PM
quattro411's Avatar
Default RE: skid plate?
it will protect the underside of your engine and i believe it also helps with aerodynamics
Old Feb 22, 2007 | 07:01 PM
cincyTT's Avatar
I'm make believe
Idont have it on mine.I think the same happened to mine before i bought it. So you are fine without running it, but like said above you'll get some lift in the front and are more at risk for some rocks to damage things. The lift is only really felt once your above 70mph.
Old Feb 22, 2007 | 07:15 PM
hmmm... i should look into getting one then... because i go over 70 just about every time i drive it....i have to see where i can get one...hopefully it wont cost an arm and a leg...thanks guys
Old Feb 22, 2007 | 08:28 PM
cincyTT's Avatar
I'm make believe
its really not that bad. But i have look around a little and havent found one. Im think i might just get some aluminum and cover it myself. All it will take is some measurements and time really.
Old Feb 22, 2007 | 09:49 PM
MeanAudiA6's Avatar
they are very expensive 260 bucks from the dealer...also they seem not to have the ones for the 2000-2004 only the 3.2s skid cover. they are very similar and will fit but not a perfect fit...i had to modify mine to fit the way i wanted it to.
Old Feb 22, 2007 | 11:12 PM
cincyTT's Avatar
I'm make believe
In that case a fabbing i will go. Thanks for the info. I really need to get my car more planted (worn suspension sucks). While im at it, i might aswell make a splitter and make it a 2 for 1 deal.
Old Feb 22, 2007 | 11:45 PM
XCLR8TT's Avatar
The "Skid Plate" serves most as a sound insulation panel.. But FYI here is a parts list for the panel and the hardware that holds it in...
4A0 805 163 socket clips (these are the ones in the wheel well)
4A0 805 137A retaining disk (part of item above)
N 015 458 1 speed nut (clips in frame)
N 907 750 01 torx socket panel screws
8N0 825 235 F Sound insulation panel.
You might be able to get a better price than the dealer from either 1stVWparts.com or WorldImpex.com Just to to their websites and enter the part numbers into their search form.
Old Feb 23, 2007 | 12:45 AM
ouTTie914's Avatar
Okay, so here's my n00b-ish question...
Does the skid plate cover the whole length of the car, or just the front end?
Old Feb 23, 2007 | 01:04 AM
cincyTT's Avatar
I'm make believe
nose till the trans/axles
