Skid Plate Falling Off
Old Jul 10, 2007 | 04:22 PM
Indiepunk's Avatar
Default Skid Plate Falling Off
So they were doing some construction at work that caused some dust to go on some cars (not mine). I took the opportunity to skip out for a bit and wash my car. On my way back the front part of my skid plate dropped down. The good part is thatI didn't loose it completely. It is being held on by one fastener/screw - whatever it is. I didnt get down and roll around in my work clothes but I will have to do so in 45 minutes. I will have to locate some tools to try to remove it. Anyone know what keepsitattached soI can find the appropriate tool to remove it?
Old Jul 10, 2007 | 04:28 PM
Audi_droptop's Avatar
Default RE: Skid Plate Falling Off
i believe all you need is a flat head screwdriver... mines came off as well... i went to get an oil change... looked like the guy was using a flat head screw driver to unscrew it... but he didnt put back on correctly so it came off... but i dont mind because i can hear my turbo better now... i think the proper name for it is "sound deadner".
Old Jul 10, 2007 | 04:30 PM
cincyTT's Avatar
I'm make believe
i never had mine but the one on the passat uses a flat head and has one 10mm bolt up front. Should use the same hardware.
Old Jul 10, 2007 | 04:31 PM
Indiepunk's Avatar
THNX.
Old Jul 10, 2007 | 06:09 PM
diehlryan's Avatar
mine is held on with torx screws.
there are 9 or 10 in all.
there are a few quick release plastic adapters in the wheel wells also. they are the quarter turn screws.
Old Jul 10, 2007 | 06:35 PM
MeanAudiA6's Avatar
T25 torx screws around 10 plus the 4 flathead turn screws....i dont have mine anymore.....lost it doing 140mph...scary stuff....sparks flying everywhere
Old Jul 10, 2007 | 09:12 PM
theTTkid's Avatar
mine were torx too.....
Old Jul 11, 2007 | 12:47 AM
M FLYTT's Avatar
yeah when i did my exhaust i decided to keep mine off... it fell off a few times before that kinda like yours with just one left holding it on... i just kicked it off the first time, and then decided to keep it off after that
Old Jul 11, 2007 | 10:02 AM
Indiepunk's Avatar
This became a disaster. It was held in by two screws with 3mm centers. One was stripped. When I got it off the inside had a nice coat of fresh oil. LookslikeI have a couple seals that need to be replaced.
Old Jul 11, 2007 | 10:58 AM
theTTkid's Avatar
eh, not quite a disaster because at least you figured out this problem before it became an even bigger headache... sorry to hear that though
