Slight grind when shifting at low rpm from 3ed to 4th gear-normal?
Old 12-20-2007, 05:54 PM
jakej's Avatar
Default Slight grind when shifting at low rpm from 3ed to 4th gear-normal?
My 01 225 with 65k, when cold, sometimes lightly grits the 3 to 4 switch. It only does it when I'm going about 25 mph and not at higher speeds and only when cold (first 10 total shifts). Is this normal? Otherwise I have an aftermarket warrenty, should I ask them about it? Thanks
Old 12-20-2007, 05:57 PM
cincyTT's Avatar
I'm make believe
Default RE: Slight grind when shifting at low rpm from 3ed to 4th gear-normal?
your just not letting the oil warm up enough it seems like.
Old 12-20-2007, 06:00 PM
WishIWasRWD's Avatar
How long is your warranty good for?
If you have some time on it, don't worry about it until it gets annoying, or impairs driving. Until then, Grind Away.
Old 12-20-2007, 06:27 PM
jakej's Avatar
How can I let the trans oil warm up? The warrenty is good for another 10k miles or 14 months, but I'm tring to plan in advance.
Old 12-20-2007, 06:28 PM
cincyTT's Avatar
I'm make believe
by letting it idle longer before driving it. If you need to go sooner, just dont shift in the higher rpms.
Old 12-21-2007, 01:14 AM
Murderface's Avatar
can't find it grind it =|
Old 12-21-2007, 10:51 AM
jakej's Avatar
I'm guessing this is normal then?
Old 12-21-2007, 11:39 AM
diehlryan's Avatar
why are you shifting to 4th at 25mph?
Old 12-21-2007, 01:08 PM
jakej's Avatar
I usually don't shift that soon, I just noticed it grits at that speed.
Old 12-21-2007, 01:21 PM
cincyTT's Avatar
I'm make believe
change the fluid to redline mt90
Quick Reply: Slight grind when shifting at low rpm from 3ed to 4th gear-normal?
