So I'm putting the TT out to pasture..
Old Oct 23, 2007 | 09:51 PM
eliTTe's Avatar
Default So I'm putting the TT out to pasture..
haha its not as bad as it sounds, I'm just getting another car so I don't have to drive the TT all the time ... found this 1985 Audi coupe GT, paid only $500 for it! it needs a little work to run(slave, fuel pump, battery, and maybe a tune up) but overall its in great condition!
Anyone have any tips as to what I should do prior to start up? its been sitting for a few years.
Old Oct 23, 2007 | 10:39 PM
XCLR8TT's Avatar
Default RE: So I'm putting the TT out to pasture..
[ol][*]Change all the fluids.[*]Lubricate everything you can.[*]Pack wheel bearings.[*]Replace belts, hoses.[*]Check suspension bushings for cracking[*]Replace plugs, wires.[/ol]
Old Oct 23, 2007 | 10:58 PM
eliTTe's Avatar
excellent, thanks xclr8tt!
Old Oct 23, 2007 | 11:15 PM
cincyTT's Avatar
I'm make believe
is that a 2.5 inline 5?
Old Oct 23, 2007 | 11:23 PM
eliTTe's Avatar
2.2L I5 non-turbo.... it will be slow, but it will make the TT seem that much faster when I drive it haha.
Old Oct 23, 2007 | 11:33 PM
cincyTT's Avatar
I'm make believe
Didnt know they made a 2.2L. I just like the rad on the side of the car to make room for the engine.
Old Oct 23, 2007 | 11:46 PM
XCLR8TT's Avatar
You could always talk with the guys at 034motorsports... they've got a 800+ WHP Audi 80 with a 20V in it.
Old Oct 24, 2007 | 12:09 AM
eliTTe's Avatar
wow thats a lot of power for a car like that, I bet it can eat a set of tires in a few seconds
yeh Nate, the motor almost hangs over the front bumper, pretty weird but I guess thats how they did it back then.
Old Oct 24, 2007 | 06:36 PM
jakej's Avatar
Along with all the fuilds (ps, pb, trans too!) change the gas or atleast put some good fuel stabilizer in it. ALSO--You'll have a difficult time drawing gas into the cylinders, because it sat so long (piston rings are now dry and untill they are moist again they well not seal and create a vacume). You'll most likely need to use a lot of starting fluid to get it running long enough to draw gas into the cylinders and re-moisten the rings. I had a simular problem when fixing a flooded car... took me a while to figure that one out.
Old Oct 24, 2007 | 09:05 PM
theTTkid's Avatar
if that isnt ghetto idk what is... lol you should tell people youll spank them with your audi and show up later on with the TT
