so my timing belt failed...a question about engine codes
Old May 27, 2007 | 09:02 PM
ouTTie914's Avatar
Default RE: so my timing belt failed...a question about engine codes
Wow! Not even the belts last!
That's an awful lot of missing teeth!
Old May 27, 2007 | 10:07 PM
XCLR8TT's Avatar
No... this is a lot of missing teeth...
Old May 28, 2007 | 06:07 AM
silvtt's Avatar
my timing belt went out when i was driving also, i was doing about ten mile an hour. I towed it to the shop an it was 5,138 to get it fixed. Most of my valves where bent and the had to send the heads to get rebuilt. Also the water pump broke into some pieces for some reason. There where many problems that went with it. They also said that the fuel pump is a must to replace when the engine is rebuilt after something like that, thats just what they told me.
2001 audi tt 225hp at 61,000
Old May 28, 2007 | 08:12 AM
225tt's Avatar
"Fuel pump", wow sounds like someone was trying to make some extra $$$. I didnt know that, anyone hear of this happening?
Old May 28, 2007 | 09:17 AM
XCLR8TT's Avatar
Doubtful that the fuel pump would be damaged by the timing belt. On older cars the fuel pump used to be mechanical, but with the fuel pump on the TT being electric and sitting back inside the fuel tank, the mechanic was definitely looking to sneak a few more $$$ into the repair.
Old May 28, 2007 | 11:56 AM
cincyTT's Avatar
I'm make believe
The stock water pump's impellers are plastic, so that was probably broken months beforehand.
Old May 28, 2007 | 03:57 PM
lehighwiz's Avatar
ORIGINAL: silvtt
isn't it true that pumps are most likely to fail after they have been idle for a long time and have dried out? i am speaking generally about liquid pumps. perhaps it was for that reason that they wanted to replace it...still seems fishy to me too.
Old May 28, 2007 | 04:00 PM
  #18
lehighwiz's Avatar
i am about 1/2 way through the disassembly stage of my head right now.. i will post pics once i have something to look at.. I stripped an allen bolt during the disassembly of the head cover and now i have to deal with that before i can proceed... i got annoyed and decided i would resume it later on.
Old May 28, 2007 | 04:11 PM
  #19
cincyTT's Avatar
I'm make believe
its always best to go back in with a clear head. when something like that hits, i to get frustrated and makes working much harder.
Juliet
Oct 30, 2012 02:53 PM
vtraudt
Dec 12, 2010 03:44 PM
Jessie2k
Aug 5, 2008 01:39 PM
satishtadi
Jul 5, 2007 05:04 PM
