Spark Plugs
Old Aug 27, 2010 | 11:39 AM
kwaskow's Avatar
Default Spark Plugs
Looking over the FAQ page, I see the following options for a stock car. Mine is an 04, 225.
SPARKS PLUGS
OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
NGK BKR6E
Autolite 3923
Denso Iridium IK20
Which is best?
Old Aug 27, 2010 | 01:27 PM
quaTTrophobia's Avatar
SPARKS PLUGS
NGK BKR6E
Autolite 3923
Denso Iridium IK20
Which is best?
PFR6Q is the o.e. NGK spark plug that you will get at the dealer or can get them in an NGK box under stock #6458 (original quipment service part. and is Platinum/Iridium)
BKR6E is NGK plug with a V-cut electrode and a copper core.
if u want Iridium in an NGK (similar to o.e.) its BKR6EIX
if U want Platinum " " " " " " " BKR6EGP
the o.e .plugs are three/four times the price of the copper.
you pays your $$ and takes yer cherce... stay with NGK .
The o.e will last 50- 70 K miles possibly but I would use the plat or irid and change every two years and the coil paks (o.e. only) every 50K. You must carefully gap the plugs.
Old Aug 27, 2010 | 09:58 PM
jakej's Avatar
Correct. Gap them correct!!!!
Old Aug 30, 2010 | 09:39 AM
kwaskow's Avatar
So, would you recommend the OE plugs?
Old Aug 30, 2010 | 07:19 PM
jakej's Avatar
I would just go with whatever is easy to find.
Old Aug 30, 2010 | 08:35 PM
ilackav8's Avatar
agreed. ive been running autolite platinums with no problems...the NGKs are strangely elusive.
Old Sep 3, 2010 | 01:37 PM
NorthD's Avatar
Default spark plugs
The best spark plugs on the market are Brisk Racing plugs You have no gapping they sit deeper and they add horsepower to your car.
run colder............ check it out http://briskracing.com
http://whanab.com/
cwedholm1
Mar 13, 2010 11:47 PM
Eric_C
Dec 13, 2009 10:48 PM
hsbertiii
Jan 19, 2008 01:42 PM
domino877
Nov 28, 2007 09:09 PM
aerostatwv
Nov 22, 2007 07:20 PM
