Speed sensor
Old Mar 15, 2008 | 11:30 PM
Red_sapphire89's Avatar
Default RE: Speed sensor
Just moved here in begining of january im from orlando florida and california lol....still getting used to the ricers that think there hot **** where i was from there was alot of rice but they knoew they wernt **** and my tt wasnt **** either it was common to see a ferrari or lambo every day...
Old Mar 16, 2008 | 05:15 AM
beachchair's Avatar
ORIGINAL: Red_sapphire89
I got a bentley and just spen 30 mins looking throught it where the heck is the speed sensor my speedometer does not work and i get a code for vehicle speed sensor
I was happy you were finally getting a Bentley. Now I'm concerned that you don't know how to use it. Did you get the companion book "How To Use Your Bentley?" Available on Amazon.
Old Mar 16, 2008 | 10:14 AM
achTTung's Avatar
OH, and you still don't have a vag-com cable? Apparently now called VCDS btw. Theres function tests you can run to see whether its the VSS or if the problems elsewhere.
Old Mar 16, 2008 | 12:56 PM
jakej's Avatar
I'm not sure about the tt, by I replaced the vss in my last car and they were several vss's. The ones near the brakes were related to abs and only needed to be replaced if your abs light was on. The vss that actually controlled the spedo was in the transmission. The car always read 0 mph, I changed the vss in the trans and it fixed the problem. The dealer wanted a ton of $$$ for replace the $10 part too. They said the entire trans needed to be dropped. I managed to do it my self by bending a wrench to barely fit in.
Make sure you order the right vss.
Old Mar 17, 2008 | 12:53 PM
How do i determine which one it is, there are 4 of them! on one each wheel! and is there one in or on our transmission on our cars?
Old Mar 17, 2008 | 02:07 PM
jakej's Avatar
I would bet its the trans one, if you just took the trans out.
Old Mar 17, 2008 | 02:52 PM
yea but this wasw accuring before i took the trans out i been looking at vagcat and my bentley i see no such sensor on the tranny?
Old Mar 17, 2008 | 03:05 PM
  #18
techbod's Avatar
like the older cars had a speedo cable now the newer ones have a sensor ( in the same place ) nothing to do with the ABS sensors and there is only one on the tranny and that should be on top pointing down to the flywheel which is how it reads the speed
Old Mar 17, 2008 | 03:11 PM
  #19
hmm thanks techbod ill take a look thursday when i go to get it as its 2 hrs away at my uncles house anyways im gonn vagcat it and see if i can find what you are speaking about thanks!
Old Mar 17, 2008 | 10:14 PM
  #20
allright vagcat is a useless pos they dont even list everything wtf? i spent hrs looking for this where is the sensor on the transmission
