Squeal from low to mid range rpms
Old Mar 2, 2008 | 06:12 PM
DEjunkie's Avatar
Default Squeal from low to mid range rpms
Need some advice guys. I've been tolerating a very light squeal for a few months. It started after I chipped the car. I can make the squeal happen when I'm in gear going from low revs to mid range revs. It dissipates as the car goes into 5 or 6k rpms. I just assume it's a belt that's making the noise, but I'm really not sure why it happens or if it's bad for the car. Could it be a bad DV?
Any advice?
Thanks in advance.
FYI, the car has 41,000 miles.
Old Mar 2, 2008 | 06:47 PM
auditech79's Avatar
Default RE: Squeal from low to mid range rpms
Take the belt off and go for a drive. If there isn't any noise then its probably the serpintine belt tensioner.
Old Mar 2, 2008 | 07:27 PM
DEjunkie's Avatar
Thanks auditech79. I'm not quite that capable with working on the car yet. But, as long as it's not hurting the car, I'll be OK until I can get some help looking at it.
Old Mar 3, 2008 | 09:13 AM
jakej's Avatar
I'd guess the belt tensioner bearing (most likely) or ac compressor. The bearing is a cheap fix and most common.
Old Mar 3, 2008 | 12:20 PM
scoTT la rock's Avatar
sounds like the serpentine belt?
does it go away after 2000 RPM?
that was the issue i had- squeal at low RPMs. looked at the s-belt and sure enough it was replacement time.
Old Mar 6, 2008 | 08:29 PM
DEjunkie's Avatar
scoTT la rock,
actually the noise starts at about 2 or 3k and continues through about 6k rpms. i'll definitely have a look at the s-belt.
thanks for all the advice guys.
Old Mar 28, 2022 | 07:56 PM
A4Dave's Avatar
Hey there
I'm new here and haven't learned all of the 12 year old girl tiktok initials, so could you tell me what a DV is?
Jackmup
Mar 14, 2012 02:16 PM
toolagit2qwit
Dec 22, 2011 04:46 PM
toolagit2qwit
Dec 21, 2011 12:11 PM
jimprib
Sep 15, 2009 10:56 PM
Quis
May 27, 2006 03:29 AM
