Steering noise
Old Jan 4, 2008 | 05:11 PM
chancebuttars's Avatar
Default Steering noise
I have an 03 TT quattro coupe my car seems to make a wining noise when i turn the steering wheel, at one point it got really loud, not sure what to do!!!
Old Jan 4, 2008 | 05:26 PM
ouTTie914's Avatar
Default RE: Steering noise
Like someone said in your other post. If you just bought the car from a dealer, take it back and let them deal with it.
At no cost to you of course! Otherwise check your power steering fluid...
Old Jan 5, 2008 | 01:50 PM
achTTung's Avatar
Did you check/add PS fluid? Thats number one on your list, you should have been thinking of that as soon as you heard the noise.
Old Jan 5, 2008 | 07:19 PM
Dolomite_TT's Avatar
I had some noise also, checked the PS level and it was low. Took it to the dealer and they found that the seal on the high pressure line was leaking. Hope this helps.
Old Jan 5, 2008 | 08:04 PM
diehlryan's Avatar
what fluid do you use to top off your power steering?
Old Jan 5, 2008 | 09:18 PM
ouTTie914's Avatar
Old Jan 6, 2008 | 12:43 PM
MeanAudiA6's Avatar
any dot 4 brake fluid will work but i;m not a huge fan of mixing different fluids....always safest to just bleed the system and add fresh fluid.
FTv2
S4
Apr 1, 2014 02:23 AM
zchb9
May 16, 2008 11:47 PM
manufan
Dec 1, 2007 01:45 PM
andresarlia
Aug 28, 2007 03:52 PM
tbrown
Sep 11, 2006 02:47 PM
