Stripped Crank Pulley Bolt! Please help.
Old Aug 5, 2014 | 01:46 AM
mikeaagesen's Avatar
Default Stripped Crank Pulley Bolt! Please help.
I got 3 out of 4 crank pulley bolts out fine, but 1 stripped. I think when I had the belt changed last, it may have been over torqued. Should I get a dremel and try carving a line across it and try getting it loose with a huge flat head screwdriver? I'm really not sure how to fix this. Should I try those screw extractor bits? I've been soaking it with WD-40 so I can try to get at it again tomorrow morning. Any help here would be awesome. Heres a picture.
Attached Thumbnails Stripped Crank Pulley Bolt!  Please help.-audi-tt-headgasket-writeup-004-small.jpg   Stripped Crank Pulley Bolt!  Please help.-audi-tt-headgasket-writeup-005-small.jpg
Old Aug 5, 2014 | 08:00 AM
bradtyler02's Avatar
You might get lucky with a set of EZ-Outs. I don't think the dremel and flat tip idea will work with torque still on the screw.
Old Aug 5, 2014 | 10:42 PM
Wasted money on crap to take it out and in the end, I hammered in the next size allen bit. Came right out. Kinda funny looking back.
Old Aug 6, 2014 | 08:50 AM
That works too!
Old Aug 7, 2014 | 03:12 AM
tties4me's Avatar
Had the same issue, hammered 1/4 still didnt work... drill out the head of the bolt so you can take the pulley off then use an easy out to remove the rest of the screw... dont hit the pulley with the drill while drilling out the head of the bolt.... once the torque is off the screw it should come off pretty easy... I used a little pb blaster for safe measure, the drill for the easy out ended up removing it before I even got to use my fancy easy out
Old Aug 7, 2014 | 03:48 PM
I'm glad its out. I am now working on loosening the timing belt so I can slide it off the cam sprocket and take my head off.
Old Aug 8, 2014 | 12:13 AM
tties4me's Avatar
Head gasket? Wish ya luck and hopefully that was the only handup
JagoKaast
B7 Models
Oct 15, 2012 06:39 PM
bgrist
Apr 14, 2010 12:58 AM
a2thy
Dec 19, 2009 01:57 PM
copper07
Nov 11, 2009 10:35 AM
WishIWasRWD
Apr 29, 2009 01:32 AM
