Stripped Halidex Drain Plug --- $750
Old Sep 30, 2008 | 05:44 PM
jakej's Avatar
Default Stripped Halidex Drain Plug --- $750
The threads on the hole were shot. I tried the oversided drain plug, drill and tap and looked into getting a bung welded on. Ended up just replaceing the houseing. Parts and labor comes to a total of $750 at a non-dealer repair shop. Good thing I have an after market warranty that covers it and I only have to pay $200 for all new parts. Heh heh. I win (for once)!!
Old Sep 30, 2008 | 06:08 PM
achTTung's Avatar
wait... you got a replacement haldex shell? Like, transfer the 'guts' to a new casing?
I called/searched forever to try to get JUST a Haldex LSC when mine went bad, only options I ever heard were LSC attached to differential for about $750, or a brand new LSC/Diff from Audi for $3000.
Where'd you get your parts?
Old Oct 1, 2008 | 08:06 AM
jakej's Avatar
Yes. It's just the case. $400 for parts. I'm not sure where the dealer got them from though. All I know is the parts are/were in Texas and need to be shipped to my area. I assume the parts are new, because this is a high end dealer (who is working on a brand new 911 turbo now). I'll let you know any more details, if I found them out.
Old Oct 1, 2008 | 06:40 PM
achTTung's Avatar
yeah, thats interesting.
i ended up getting a used unit from a audi tech that stashed an unclaimed, misdiagnosed unit. almost new. paid $500, i can sell the stock controller and almost make my money back if i want.
Old Oct 2, 2008 | 01:52 AM
ray@RAIMOTORSPORT's Avatar
ive never seen just a case for sale. also no drainplug is too stripped to be either removed or tapped through.....
Old Oct 2, 2008 | 01:22 PM
jakej's Avatar
It's more of a how it seals/sits, then a retap issue.
Old Oct 2, 2008 | 03:40 PM
myxyzxo's Avatar
SoCal Crew Member
Would it be possible to weld a little nut ontop of the Drain Plug ? That way you can use a socket and remove it. While removing my head, the bolt for the manifold stripped. Ran to 5 different stores to try n find something that will remove it.. No luck, so in the end we just welded a nut ontop of the bolt..
Old Oct 2, 2008 | 05:42 PM
jakej's Avatar
That's pretty much what a bung is. Theres just not enough room, plus the way the oil goes in (sideways), makes it more difficult.
Old Oct 2, 2008 | 07:54 PM
GHETTOxWHITExBOY's Avatar
reverse drill bits and an extractor set would have done the trick
Old Oct 2, 2008 | 10:28 PM
jakej's Avatar
Threads in the pan. The bolt was out already.
