Supercharge
Old Aug 27, 2007 | 03:26 PM
cincyTT's Avatar
I'm make believe
Default RE: Supercharge
ORIGINAL: eliTTe
you can put your stock back in and we can line them up ... your stock DMFW is a heavy chunk of rotating mass, its going to slow you down, not create more torque.
22lbs vs 14 or even 7lbs, the revs on the lighter ones are going to move pretty fast.
Old Aug 27, 2007 | 04:04 PM
ooantipostoo's Avatar
Yah it will rev faster but torque is decreased in anycar you put a lightfly wheel on it helps on the top end of gears not lower.
Old Aug 27, 2007 | 04:11 PM
cincyTT's Avatar
I'm make believe
You have a tiny turbo that has peak TQ at ~2300rpms to high 4k range
Old Aug 27, 2007 | 04:12 PM
Ok so please explain what that means. When i put my lightfly wheel in the carit felt a hell of alot slower than it was stock.
Old Aug 27, 2007 | 04:36 PM
eliTTe's Avatar
picture this... you have 2 eaqual runners whose peak running speed is 12mph ok, you tie a brick to a rope and tie the other end to the the runner and let it drag behind him, you do the same with the other runner but instead of a brick you use a cinder block... if both runners take off the starting line at the same time, the runner pulling the brick will reach his optimum speed of 12mph first.
the brick is the LWFW and the cinder block is the DMFW.
Old Aug 27, 2007 | 04:40 PM
So this really doesnt explain why my car was slower after i put in a lightfly wheel...
Old Aug 27, 2007 | 04:46 PM
eliTTe's Avatar
something is either wrong with your clutch/flywheel or your butt dyno is off.
Old Aug 27, 2007 | 04:47 PM
  #18
Clutch was replaced to. Im pretty sure i can tell the difference of something suckign you back in your seat as it not sucking you back....
Old Aug 27, 2007 | 04:51 PM
  #19
eliTTe's Avatar
what clutch did you go with? did you install it yourself?
Old Aug 27, 2007 | 04:56 PM
  #20
WishIWasRWD's Avatar
Did you eat too many donuts while it was in the shop???
