sway bar???
Old Aug 14, 2007 | 03:49 PM
DurTTy's Avatar
Default RE: sway bar???
i did the dogbone bushing from SE from TTstuff.
it was a bihatch to install ,.... had to compres sthe to f@$K with a 20 ton press. i will admitt the shifts are crisper but now i got vibrations coming from a lose clip that attaches the plastic cover over the hatch. i read those clips are plastic and notorious for breaking. ... its not so bad when the stereo is on but.. yeesh .. it vibrates like a motha motha.
but i do want to know also how was the install on the rear bars. was it easy ? did it require a lot of tools? can you speciify which tools ... i know im asking too much now lol
Old Aug 14, 2007 | 03:55 PM
twenty8red's Avatar
wow, i've heard that the dogbone bushings are very easy, like a 20min job. hmm, maybe i'm in for a long night. can anyone else verify this?
Old Aug 14, 2007 | 03:58 PM
ouTTie914's Avatar
This is for an A4 but seems pretty straight forward. Clicky!
Old Aug 14, 2007 | 04:14 PM
diehlryan's Avatar
ORIGINAL: twenty8red
The dogbone install is easy.. really easy. I dont understand why some people have problems. Maybe the energy suspension kit from ttstuff uses a stiffer bushing. I wouldn't know. I used the kit from ECSTuning.
I also heard the rear sway should be about 90-120min job.
Old Aug 14, 2007 | 04:39 PM
twenty8red's Avatar
cool, that's the kit i got.
Old Aug 14, 2007 | 05:14 PM
AudiOso's Avatar
I went with the H&R bars front and rear. 25mm up front and 21mm rear. Now it has a touch of oversteer.
Old Aug 14, 2007 | 05:39 PM
Murderface's Avatar
I'm thinking you're right. The sandwich bushings were a b1tch, I used two 6" C-clamps and even then it wasn't that easy to recompress them. And on some TT's there's a little bar that gets in your way when you reinstall it.
And make sure you just get a torque wrench and torque those bolts right (18.5 ft-lbs for the small, 37 ft-lbs for the big) else you probably won't torque them enough and 1. your bolts will fly the f*** out and 2. you'll get hella vibration.
Old Aug 15, 2007 | 11:33 AM
  #18
cincyTT's Avatar
I'm make believe
I just put all my socket with the extension and then got more of my body weight over it and it cought in no time. Torqueing the bolts again about 50-100miles later is important also with new stretch bolts
Old Aug 15, 2007 | 09:52 PM
  #19
twenty8red's Avatar
ok, so i got my sway bar on and man does it make a difference!!!! the car feels much more neutral, more planted and much stiffer. it took us about two hours total to get it put in. i had to drop the muffler and heat shield which i wasn't expecting to have to do. i could do it next time in about 30 min. if you haven't already put one on i highly recomend it.
Old Aug 15, 2007 | 09:55 PM
  #20
cincyTT's Avatar
I'm make believe
so did you take the time to put the sheild back up?
