Tcarbon FMIC vs Forge Motorsport FMIC 180 HP Quattro
Old Jul 29, 2007 | 01:53 PM
  #31
cincyTT's Avatar
I'm make believe
Default RE: Tcarbon FMIC vs Forge Motorsport FMIC 180 HP Quattro
ORIGINAL: DurTTy
cincy the link to the trubo doesnt work i found this though http://www.pwrhaus.com/products.html#garrett60trim
there are 4 turbos there along with a bunch of other stuff. scroll down and let me know if im looking at the right thing there.
t3 60trim and a t3t4 60trim are very differnt (300whp vs 500whp turbo). I fixed the link above or you can just click here
Old Jul 29, 2007 | 01:59 PM
  #32
cincyTT's Avatar
I'm make believe
ORIGINAL: DurTTy
ok here is the response i got from Tcarbon on the FMIC 180HP Quattro
The product doesn't have a description or pictures because the kit isn't officially launched to the public. We're currently working on the instructions which is why the other information hasn't been added to the site. The 180 and 225 kit is very different since the 225 has a different turbo, and a completely different tubing set-up.
the turbo has nothing to do with it. The reason the 180 and 225 take differnt paths is because the 180 has to get down to the smic and get back up to the passenger side tb and the 225 doesnt so it makes an easier path (avoiding a pancake pipe) to the smic and around. The easiest solution fora fmic for a 180 is a apr/evom style set up or use new piping like a eurojet kit. Speaking of, EJ claims they will have a fmic for the TT out soon enough.
  #33
DurTTy's Avatar
ok, yea its alos at the pwrhaus site. its the last one. can any1 direct me as to what the heck the difference is between, .42, .63, .82 A/R is ... or even what that means?
Old Jul 29, 2007 | 02:00 PM
  #34
DurTTy's Avatar
also ... Tcarbon has indicated back to me right now that they are going to advise me as to what the release date is gonna be. i asked them why they stated on their site that the kit was available as of april 2007 if they had not rolled it out yet. ... i will keep you al posted
Old Jul 29, 2007 | 02:15 PM
  #35
cincyTT's Avatar
I'm make believe
ORIGINAL: DurTTy
you mean .48 not 42 a/r
It is the size of the turbine housing. The smaller the number the faster the spool, the larger the number, the more power up top and greater flow. It really depends on the turbo you choose if you should go with a .48 or .63, no street turbo needs a .82.
t3 housing come in .48 .63 .82
t25 housings come in .64 and .86
the .64 is about the same size as a .48 and .86 is close to the .63.
T3 housings also have a larger turbo inlet than a t25 and will flow better. Most T3's dont come with internal wastegates and just about all t25 housings do.
Old Jul 29, 2007 | 02:20 PM
  #36
cincyTT's Avatar
I'm make believe
if you have some skill, you can make your own apr/evo kit for a 180 like this.
just need a couple pipes, a map sensor, and a simiular core (treadstone makes a nice one)
Old Jul 29, 2007 | 03:24 PM
  #37
neur0tic's Avatar
I agree. On the 180, since you don't already have a SMIC on both sides... instead of trying to trun all your own piping around your engine bay... you'll be better off with a "C" style intercooler with an inlet and outlet on the same side so you can plug and play.
By "plug", I mean install. By "Play", I mean drive around and pick up milfs and throw the kid in the trunk.
By "Trunk", I mean that sorry excuse of a backseat we have. lol
Old Jul 30, 2007 | 08:32 AM
  #38
DurTTy's Avatar
Hey,
What is the wastegate setup on the K04,K03? What is the A/R of our turbine wheels? Also this is what i managed to find bout the T3 and also another turbo thats kinda interesting.
The GT28RS is also know as the Disco Potato. This is a ball bearing turbo featuring a internal wastegate.
Specifications:
[ul][*]Compressor Trim: 62[*]Turbine Trim: 76[*]Compressor A/R: 0.60[*]Turbine A/R: 0.86[*]Compressor Diameter: 60mm[*]Turbine Diameter: 53.85mm[*]Corrected Air Flow: 33 lbs/min[*]Wastegate: Internal [/ul]
Garrett T3 Super 60 Turbocharger
This turbo is for 4cyl applications and will flow up to 350hp.
Specifications:
[ul][*]Compressor Trim: 60[*]Compressor A/R: 0.42[*]Turbine Trim: 68[*]Turbine A/R: 0.48[*]Corrected Air Flow: 33 lbs/min[*]Wastegate: Internal [/ul]
Old Jul 30, 2007 | 08:59 AM
  #39
DurTTy's Avatar
to be honest i really dont know where or what kind of MAP sencor i would need to get, i would rather not play around like that. but i would be nice to save a bit of cash doing a customer fitment. plus i cna get forge silicone hoses.
Old Jul 30, 2007 | 12:06 PM
  #40
cincyTT's Avatar
I'm make believe
You wont need a new map. The 28rs and t3 60trim are very simular in power but the t360 will spool faster and make just a little less hp overall (10-20hp) at 1/2 the cost. A pagparts.com kit with everything you need to bolt it on should be around $3-3.5k
