Temp Gauge - 2005 TT 1.8 100Kmiles
I test drove a 2005 TT today with 110K miles. Decent shape being a bank repo. My only major concern was -
the temp gauge was constantly registering one notch below H. Where does the temp gauge usually run on a TT?
Thanks in advance,
David
Thanks in advance,
David
Vertical is normal. Reading low may be a thermostat stuck open, or a faulty gauge in the cluster (common problem, $900 repair). MAKE SURE the car has had a timing belt replacement with tensioner and water pump. They need to be replaced every 60k miles. Ignore ANYONE that says that isn't true - they do NOT know the TT history!
I bought the CARFAX report on the TT. The major repairs noted were-
42K miles - Battery replaced, Brake Fluid flushed/changed
98K miles - Thermostat replaced
101K miles - maint inspection completed, found out today that this service included a timing belt/water pump replacement!!
The above were done at a Audi dealer.
Current miles - 110K
Thanks, David
Thanks, David
Russell2686
Jul 8, 2009 11:55 AM
