Temp Gauge - 2005 TT 1.8 100Kmiles
Old Apr 28, 2013 | 01:03 AM
rdavid.phillips's Avatar
Default Temp Gauge - 2005 TT 1.8 100Kmiles
I test drove a 2005 TT today with 110K miles. Decent shape being a bank repo. My only major concern was -
the temp gauge was constantly registering one notch below H. Where does the temp gauge usually run on a TT?
Thanks in advance,
David
Old Apr 29, 2013 | 03:16 PM
MCPaudiTT's Avatar
Vertical is normal. Reading low may be a thermostat stuck open, or a faulty gauge in the cluster (common problem, $900 repair). MAKE SURE the car has had a timing belt replacement with tensioner and water pump. They need to be replaced every 60k miles. Ignore ANYONE that says that isn't true - they do NOT know the TT history!
Old Apr 29, 2013 | 08:24 PM
Default 2005 tt
I bought the CARFAX report on the TT. The major repairs noted were-
42K miles - Battery replaced, Brake Fluid flushed/changed
98K miles - Thermostat replaced
101K miles - maint inspection completed, found out today that this service included a timing belt/water pump replacement!!
The above were done at a Audi dealer.
Current miles - 110K
Thanks, David
Old May 3, 2013 | 10:54 PM
Purchase tomorrow - the 2005 TT. It is about 100 miles from home so should have fun driving it back - hope no speeding tickets!
badone
Oct 3, 2014 11:19 AM
zedea
Jan 18, 2013 03:11 PM
Russell2686
Jul 8, 2009 11:55 AM
white95coupe
Dec 23, 2007 08:40 AM
dsrtibb
Jul 24, 2007 08:00 PM
