Temp gauge problem
Old Oct 19, 2020 | 08:11 AM
Randy Kirschmann's Avatar
Default Temp gauge problem
Hello,
I just changed the valve cover gasket on my '03 1.8 TT Roadster- and immediately afterwards the Temp gauge stopped working. Makes no sense to me since the two are seemingly unrelated, and I disconnected no wiring (except the coil packs), etc. just some hoses near the corner of the valve cover.
Does anyone have a diagram of how many temp sensors there are, and where they're located?
Any help at all on trouble-shooting this issue would be appreciated...
Thanks in advance.
Old Oct 21, 2020 | 02:45 PM
jjt1234's Avatar
My guess is the water temp sensor has either gotten loose or just needs to be replaced. im sorry, I thought I had one in the garage. I counld have given you the part number. Its an easy fix and its located on the drivers side of the enginge. Its not difficult to change. Im pretty sure all the normal part stores would have it. In the meantime Ill look for a part # for you. Its also on youtube.
Old Oct 21, 2020 | 02:50 PM
jjt1234's Avatar
Default https://www.carparts.com/details/Audi/TT_Quattro/Standard/Coolant_Temperature_Sensor/
Try This
Old Oct 21, 2020 | 02:51 PM
jjt1234's Avatar
carparts.com
Old Oct 21, 2020 | 04:06 PM
Hey thanks,
I did some research and looked at a couple youtube vids also. I ended up ordering a new ETC (?) sensor- what you're talking about :-D Should be here tomorrow. You're right, didn't look to difficult to swap out, and not an expensive part either...
Thanks again.
Old Oct 22, 2020 | 11:18 AM
jjt1234's Avatar
Originally Posted by Randy Kirschmann
Hey thanks,
Thanks again.
Super. Interestingly, I changed that sensor out as part of replacing a part that was leaking nearby. 6mos later that new sensor had to be replaced. So much for preventive maintenance. Lol
Old Oct 22, 2020 | 04:39 PM
Wow.... you just never know what's going to break next, you know?
Isn't that fun! :-D
Old Oct 23, 2020 | 07:55 AM
jjt1234's Avatar
Wink
The best part!! Lol
Rudy's 01 TT Quattro
Aug 11, 2013 09:28 PM
dhillon
Feb 23, 2009 07:14 PM
rpickoff
B7 Models
Jun 12, 2008 03:12 PM
dmayer75
Mar 4, 2008 08:14 PM
keko2004
Aug 23, 2006 05:03 PM
