Thoughts on wet kit
ORIGINAL: achTTung
Who is it that sells the kit that sprays into the turbo to kill lag in big turbos on little engines?
It was in EC a few months ago, but all my mags are still in NY....
would this kit work on a tt i am actually thinking about doing this now...
http://www.sfxperformance.com/parts/COM82016.htm
i want a zex kit i like the purple bottle..call me gay i like purple lol
Whats with all the hating? The 50 wet shot is perfectly safe if shot when said. The shot settings are for NA whp. Since this is FI, the results are amplified. A 75shot adds 100whp on a stock turbo. There are several people with 300whp dynos on a ko3 and with a 75shot. These people also run 12's.
You only need to pull a deg or 2 of timing out with lemmi the days you plan on using it, not that hard and far from needing a ems. hell, the cool temps of the nitrous will lower the iat's and allow you to keep timing the same... again, FI. Just make sure you are using 7's and properly gapped plugs with this.
As for kit, look into the NX dbw kit since thats what we use. Outinfront (now in Iraq) used it and worked great for him.
The first nitrous system designed specifically to spool-up turbocharged engines
Turbos make incredible power on any engine, but the downside is that it takes several seconds for the turbo to build power producing boost. The ZEXâ„¢ Turbo Nitrous System eliminates this boost lag by injecting a shot of nitrous when the engine goes to wide open throttle. This nitrous generates additional exhaust volume that spools the turbo up instantly. Once the turbo builds boost, the ZEXâ„¢ kit automatically shuts off using the supplied, fully adjustable boost switch.
Along with excellent turbo response, the ZEX™ kit will also provides maximum engine safety and ease of use. The ZEX™ nitrous system uses an advanced technology called Active Fuel Control™. This exclusive ZEX™ technology monitors the nitrous bottle pressure and adjusts the kit’s fuel enrichment so you are never too rich or too lean. Additionally, with patented electronics that monitor your TPS sensor, the ZEX™ kit reliably activates only when you go to wide open throttle.
Exclusive ZEXâ„¢ features like these set the industry standard for performance and safety. For more information about the ZEXâ„¢ Turbo Nitrous System or any other ZEXâ„¢ product, call us at 1-888-817-1008, or visit us online at www.zex.com.
Quick Summary
Product: ZEXâ„¢ Turbo Nitrous System
Part Number: #82218
Features & Benefits:
• Eliminates boost lag for instant turbo power
• Shuts off nitrous once the turbo has spooled-up
• ZEX™ Active Fuel Control™ adjusts fuel enrichment with variations in bottle pressure so that you’re never too rich or too lean
• ZEX™ electronics use the vehicle’s TPS sensor to activate the nitrous system only at wide open throttle
• Adjustable from 25 to 75 hp
Quick Summary
Part Number: #82218
"Wet" Nitrous System 55-75hp
PART #82021
None of these are in your basket
$629.95 ea.
QUANTITY:
A complete "Wet" nitrous system. Everything is included for a safe, proper installation.
• Designed to work safely on stock type engines, but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. The ideal nitrous system for any fuel injected vehicle.
• All major components are factory pre-assembled inside the "Nitrous Management Unit". Easy, plug and play, two-hour installation.
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
• ZEX "Wet" nitrous systems activate at wide-open throttle using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable. "You've done all the bolt-ons....cold air intake, performance exhaust, underdrive pulleys.... you want more power....you MUST have more power...." It's time to step-up....your ready for some serious power. A ZEX Nitrous System bolts on in just two hours and gives you the kind of horsepower advantage that leaves the next guy you beat with the "what just happened?" look.
[hr]Cincy I search for "NX dbw kit" I can't find a single thing nothing even close???[hr]
PART #82021
$629.95 ea.QUANTITY:
its called drive by wire, they call it fly by wire. Sorry you didnt even look at their website and make the connection. Didnt think i had to spoon feed you still. Not to mention you just typed it wrong and i didnt
