Thoughts on wet kit
Ummm, you can only do wet one way.
You either do one preTb or a direct port method with 4 foggers. There is no other way to do it. I can see you venting the block in a very bad way.
Hmm I think I might get rods do a 75shot=100hp and uni tune 26psi with stock turbo run a fmic with water cooler mist full 3in exhaust....thatd put me at like 400hp 350awhp ish
http://www.tunerschoice.com/xq/aspx/...qx/Product.htm
There is a kit by "nos" but i prefer nx or zex to be honest...
http://www.tunerschoice.com/xq/aspx/...tLargeView.htm
zex setup
Basically ill have to build a custom setup i wish i could find foggers that the injectors screw into so i dont have to drill or tap anything i saw them at a autoshow once on a a4 i dont know if they were custom made or not but...
[hr]http://www.nitrousdirect.com/jets.html
omg looky what i found but i dont think there fogger i think there direct port spray but im getting closer
zex setup
zex setup
[hr][hr][hr][hr][hr][hr]
Heres What im Stronly Considering:
1)50-75 shot direct 4 fogger
2) 4bar fpr
3) Unitronic Tune (25psi)
4) 3" dp and blueflame (no cats)
5) Meth Injection
6) Fmic (water misted)
oh almost forgot new hoses because the stock turbo hose collapses under high boost
That outta put out some big hp numbers at the wheels
zex setup
2) 4bar fpr
5) Meth Injection
ORIGINAL: cincyTT
You make my head hurt.
oh and thats the kit im gonna order (but the nozzles are wet fan spray i need fogger) with a maximiser kit (two bottles) blow down tube...window timer...purge kit(maybe) two auto bottle heaters
