Timing advance
Old Jan 23, 2009 | 03:36 PM
warranty225cpe's Avatar
Default Timing advance
So my little burp/stutter I hear at idle almost went away entirely when I installed my TIP, but it's still there. I've often heard that a little (100-200rpm)bump in the timing can get rid of this, and also give a little better throttle rsponse/performance. I have contacted a couple VAG owners in the area to see if they can help me. I've gotten a good response, and will soon be hooking it up. Any thing I should remember when doing this? Anything else I should do to the TT while I have it hooked up to VAG? Also, my plugs are gapped to stock.
Last edited by warranty225cpe; Jan 23, 2009 at 03:38 PM. Reason: I'm a chronic misspeller
Old Jan 23, 2009 | 04:12 PM
cincyTT's Avatar
I'm make believe
its not timing, its increasing the idle rpm. You need either unisettings or lemmingwinks also to increase the idle. Its a free download and if someone has a vag they should have it also.
Old Jan 23, 2009 | 04:39 PM
randomloginname's Avatar
I am almost positive you can do this with ross tech software / vag com. achttung hooked up to my car after I got the dogbone installed, because I wanted to turn the idle up a bit, I dont remember why we didnt though... :-?
Old Jan 23, 2009 | 04:43 PM
yes that is what I meant. how much should I increase? Till it smooths out?
Anything else I should do while hooked up to VAG?
Old Jan 23, 2009 | 04:45 PM
cincyTT's Avatar
I'm make believe
basically. It could take 50rpms, it could take 200rpms. Mine is set to ~850rpms so i dont hear the FW anymore
Old Jan 23, 2009 | 05:12 PM
Awesome. Little increments untill I get desired idle. I wonder if they can add a feature like that to the liquidTT(would be cool).
Old Jan 23, 2009 | 05:16 PM
cincyTT's Avatar
I'm make believe
As of now its just a reader, not writeable.
Old Jan 23, 2009 | 06:44 PM
achTTung's Avatar
because my $50 laptop only holds about a 5 minute charge, and it took me 4 and a half minutes to find the block to adjust the idle.
I really need to vag working on my netbook.
Old Jan 23, 2009 | 10:04 PM
Ha, that was why, it wasnt a complaint, just a foggy memory :-)
Old Jan 23, 2009 | 11:50 PM
achTTung's Avatar
no biggie.
doesn't change the fact that I need to get my good laptop to run vagcom though.
