Timing Belt?
Old Feb 10, 2008 | 05:14 PM
MeanAudiA6's Avatar
Default RE: Timing Belt?
not a bad price esp since audi wanted over 1000 without waterpump installation
tyler i though you said you did your timing belt?
Old Feb 10, 2008 | 05:15 PM
achTTung's Avatar
You're not gonna see a difference in the stretch bolts, unless you're using some precision measuring devices. The point is, they've been stretched once, and your torque numbers when you bolt them down will not be correct. Theres a chance they loosen up or fail. Point is, they're replaced for a reason.
Old Feb 10, 2008 | 06:41 PM
Cape2003TT's Avatar
Thanks to everyone for answers/info and DIY and supplier links. Great thread.
Old Feb 11, 2008 | 12:07 AM
tom1222's Avatar
ORIGINAL: Red_sapphire89
a vdub dealer did mine for 600
Including parts??
Old Feb 11, 2008 | 12:12 AM
tom1222's Avatar
ORIGINAL: projlightning
I was told by a local Audi mechanic that the ECS does not include the hydraulic tensioner which is also needed....is this true?
I never heard of an "Hydraulic" Tensioner?? Here is what they list what is included in their Ultimate kit:
ECS Tuning Ultimate 1.8T Timing Belt Kit[/align]The ultimate kit just got better. Now with engine seals & motor mount bolts. Does Not come with coolant[/align]
This kit put together by ECS Tuning was assembled to include everything required to perform a proper timing belt job on your 1.8T. This complete kit includes all the parts which have been known to frequently fail. Failure of any ONE of these parts will most likely damage the timing belt and result in catastrophic engine damage. Kit includes the following parts:
[ul][*]OEM timing belt made by Continental[*]OE tensioner Roller made byNTN-Japan[*]OE tensioner assembly made by NTN-Japan[*]OE Idler roller (comes on the tensioner assembly)[*]Hepu water pump with metal impeller[*]Conti-Tech accessory drive belt[*]Behr thermostat[*]ECS/OEM motor mount bolt kit[*]Camshaft seal[*]Crankshaft seal [/ul]
Looks like it includes pretty much everything that is needed.
Old Feb 11, 2008 | 05:15 PM
achTTung's Avatar
OE tensioner assembly made by NTN-Japan <-- Hydraulic tensioner
Its the piece you need to pull the pin on once you get the belt installed.
Old Feb 12, 2008 | 09:48 PM
Agnt008's Avatar
that's the one i was going to buy. It's $400 bucks and i believe it comes with some lightweight underdrive pulleys (i don't know what that means or how it helps my engine.. anyone want to explain this?)
Old Feb 12, 2008 | 10:07 PM
  #18
vegastt's Avatar
Lightweight pulleys are to make rpms come on faster due to less rotational weight.
I dont think they are necessary there is a thread on VW that shows a lose of overall HP after install.
Old Feb 12, 2008 | 10:23 PM
  #19
Agnt008's Avatar
that wouldn't make sense that you would lose HP with lightweight pulleys... i'd like to see research backing this up.
Old Feb 13, 2008 | 01:05 AM
  #20
vegastt's Avatar
It was a before and after dyno run with neuspeed pulleys.
Now that I think about it they might have been underdrive pulleys.
Ill search VW for the thread.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
