Timing Belt Parts ?
Old May 2, 2008 | 02:14 PM
Audi Addict's Avatar
Default Timing Belt Parts ?
I work for VW dealer and my parts guys are not certain on the timing belt/water pump parts. I have parts list for AWP engine in a Beetle Turbo S and everything looks right. I want to make sure I am not missing an important part.
~So, do they line up directly over brands with the same engine code? (paging Cincy!!!)
Old May 2, 2008 | 08:06 PM
XCLR8TT's Avatar
Default RE: Timing Belt Parts ?
From the Dieselgeek.com site.
Kit includes (click part number to see picture.): 06B 109 119A Timing Belt, Continental same exact part as OE
06B 109 243D Timing Belt Tensioner, same exact part as OE
06B 109 477 T-Belt Damper w/included 06B 109 244 roller, same exact part as OE.
06A 121 011T Graf or Hepu Water Pump with Metal Impeller (
050 121 113C Stock 87 degree Behr German Thermostat with 059 121 119 o-ring seal.(Behr is OE manufacturer)
06A 121 121C Thermostat housing cover (plastic, replace every time you touch it!), same part as OE.
038 103 085C "Extra Coverage" DPH German Cam Seal X 2 (one for behind cam position sensor, replace if leaking), better than OE
06A 260 849C Serpentine Accessory Belt, Continental, same exact part as OE
N 105 167 01Always-Replace Small OE Motor Mount bolts x2 (torque: 30 lb. /ft. + ¼ turn)
N 102 096 03 Always-Replace Large OE Motor Mount bolts x2 (torque: 74 lb. /ft.)
Old May 2, 2008 | 08:28 PM
achTTung's Avatar
parts guys are not certain on parts
Seems to be the problem at 3 out of 4 dealerships I've tried for parts. Go in looking for car parts, but always walk out with a headache.
Went for a haldex filter once, the guy took 5 minutes looking at a shelf, and then brought me an oil filter. He didn't know what haldex was. Very sad.
Old May 3, 2008 | 03:02 PM
cincyTT's Avatar
I'm make believe
all transverse 1.8t's use the same parts, With maybe the exception of the Bettle but im not 100% sure on that.
But steve should have everything listed above
Turbonator
Sep 19, 2017 02:03 PM
tonyguzman
May 7, 2010 08:22 AM
crosswire
Feb 1, 2008 08:10 PM
aikibil
Oct 19, 2007 11:17 AM
massas4
Mar 6, 2006 09:45 PM
