Timing Belt Question.
Old Apr 18, 2009 | 09:33 PM
nyone8t's Avatar
Default Timing Belt Question.
I am currently working on a 2000 audi tt (ATC engine code).
I am a little confused on how the crank needs to be aligned. The belt is completly back on, I made sure the cam was at TDC. What needs to happen with the crank pulley. Im using blueTTop's write up and the only thing that i couldnt figure out its this. I see the bump coming off the crank pulley itslef but im not seeing any notches or anything to line up.
Ive talked to a few friends but im jsut not seeing what needs to happen.
Any help or pictures would be appreciated.
Old Apr 19, 2009 | 09:31 AM
achTTung's Avatar
the alignment marks for the crank are on tbe flywheel. one notch on flywheel, one on housing. small inspection window may/may not be covered with a rubber plug. both the crank notch and the cam notch need to be in alignment. make sure you turn the crank over by hand a couple rotations before you start the car to make sure you dont have any interference
Old Apr 19, 2009 | 02:47 PM
Neiman45's Avatar
I too have the ATC engine, same model year, and I did the belt myself using this writeup...http://www.amp82.co.uk/tt/timingbelt
I found it to be the best, with all respect to others.
Reference step 8 and click on all the pics.
Old Apr 19, 2009 | 09:53 PM
nyone8t's Avatar
Alright thanks guys apreciate the info.
Now ive got the notch on the flywheel in view and im about a tooth advanced on the cam.
Is this ok? my friend who works at autobahn on central ave in albany told me its ok to advance timing a notch says that what he does when he does tb's.
Thanks again for the info.
Yagimax
Sep 26, 2012 05:29 PM
sollyd25
Jan 11, 2011 01:01 AM
Jessie2k
Aug 5, 2008 01:39 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
cdf619
Oct 25, 2005 05:56 AM
