Tips or Tricks to puting wheels back on???
Old Aug 1, 2007 | 02:39 PM
zero388's Avatar
Default Tips or Tricks to puting wheels back on???
Ok well I spent two hours last night trying to put my wheels on. I only got one of them on and that was pure luck. I do have spacers so that makes things a little more complicated. So for all you guys out there that take off and put back on your wheels on a regular basis let me know if you have any hints or anything. It could be that it just takes a lot of work and patience but it has got to be easier than it is for me....
Old Aug 1, 2007 | 03:10 PM
.clipse's Avatar
SoCal Crew Member
Default RE: Tips or Tricks to puting wheels back on???
2 hours O_O
whoa. when tightening the bolts, always tighten the top 1st. and vice versa when taking them off (i.e. - bottom one 1st)
i have spacers too. i just position the spacer and align the wheel to where i can see the hub and rotate the wheel until i can see it then hand tighten the bolts then cross bar all 5. i ono that's my method which shouldnt take more than 20-30 min.
Old Aug 1, 2007 | 03:17 PM
zero388's Avatar
thats the thing I cant get the bolts and the spacer to line up with the holes on the brake at the same time. The spacer will never stay stay at the right spot.
Old Aug 1, 2007 | 03:36 PM
diehlryan's Avatar
thread the lub bolts into the spacer while the wheel is off the car.. then you should be able to sit the whole spacer/wheel assembly on the hub just like it was a wheel by itself..
and no offense but I can see why the FMIC install turned out to be so tough.
Old Aug 2, 2007 | 12:11 AM
zero388's Avatar
Well I got my other wheel back on in about 8 mins... I have no idea what I did different but it worked so thats good.
Old Aug 2, 2007 | 12:50 AM
TTurbonegro's Avatar
u need the tool......dunno what its official name...its a threaded rod..about 3-4" long..screws into your car..put it on the top ..then u hang the wheel on that and put the other bolts in...unscrew the rod...and put the last lug in.....takes bout 45 sec. must have for any euro
RiccardoBrizzi
Oct 4, 2013 09:44 AM
Zaphod
Jun 16, 2013 08:06 PM
davidtarnow
B7 Models
Jun 28, 2012 03:16 PM
mr peepers
Mar 30, 2009 11:40 AM
boostedB6
May 23, 2006 07:32 PM
