Tire wear out
Old Aug 27, 2009 | 12:13 PM
gtsboi329's Avatar
Default Tire wear out
i have a 2001 180FWD TT I went to get my oil change yesterday and I noticed that my DRIVER front tire was wearing out but the weird part is that is wearing off from the inside of the tire not the outside. I do remember i got my alignment around late May. Has anyone have this problem before? Or How did you guys fix it? Thanks!
Old Aug 27, 2009 | 06:12 PM
warranty225cpe's Avatar
You need an alignment often in a TT. You will be changing tires often anyways.
Old Aug 27, 2009 | 06:24 PM
jakej's Avatar
You need to get your toe-in/camber alignment checked. Also air pressure affects tire wear.
Old Sep 1, 2009 | 08:11 PM
achTTung's Avatar
the stock, quite compliant rubber suspension bushings let suspension geometry change too much. Tires push against each other under cornering loads and what have you, and wear prematurely. Upgrade a-arm bushings to stiffer ones, and your tires will last longer.
adioman6000
Nov 9, 2010 10:57 PM
fireman9585
May 19, 2010 08:25 AM
fireman9585
Jun 9, 2008 06:24 PM
fireman9585
Jul 18, 2007 01:51 PM
seaurchin99
May 26, 2005 11:39 PM
