tires on 2001 audi tt
Old Apr 2, 2012 | 02:27 PM
rvdtsunami's Avatar
Default tires on 2001 audi tt
putting on my stock rims but looking at tires would there be any problems putting on the 225 50 17? or should i just stick with the 225 45 17? also does anyone have some kind of kit to fix the glove compartment the latch broke.
Old Apr 4, 2012 | 01:59 PM
Ashaudi's Avatar
You would have too buy the whole glove compartment no kits that I know of
Old Apr 9, 2012 | 12:42 AM
hunTTsvegas's Avatar
Also, I'm not sure that 225/50-17 would make much of a difference over 225/45-17 other than increase sidewall. The car was designed around the latter tire size therefore, by manufacturing standards, is the optimal size. Although, it's definitely an acceptable size. What is the particular reason if you don't mind me asking?
Old May 13, 2012 | 10:42 PM
rodhotter's Avatar
i put 205-50-17 mich pilot exalto A/S on my 01 TT, less weight, less cost, and a little more sidewall to protect wheels from penna. potholes! very happy with the results, i added motorsport-tech 25 + 30 mm spacers to my factory 7.5" fat fives for a good look
Old Jun 2, 2012 | 08:16 PM
warpedhalo's Avatar
No no no, there is totally a glove box fix. It's pretty easy... I did it. Here's the link. I had to fill the hole under the latch itself with jb weld because there was too much play with the set screw, then re-drill the hole out smaller. But all in all this guide worked for me. Just make sure you fit the latch in the piece, mark your hole to drill, drill a small dimple, re-allign, and drill while holding the latch so it doesn't come out all crooked. It's a job, but it totally works.
oh, and all you need are the set screws unless your tabs do not retract by themselves. If you just broke off the latch you can ignore like 80% of the guide, you only have to do the set screw part like I did.
Old Jun 12, 2012 | 10:28 AM
NorthD's Avatar
the biggest tire we have put is a 245/40/18 and I do not suggest that. LOL
that size is fine another good size is 225/40/18
Juliet
Dec 27, 2012 08:42 AM
GillzAudi
Jul 30, 2008 01:34 AM
silverttq
Jul 23, 2008 01:13 PM
hoogaface
25
Sep 19, 2006 05:26 PM
orodrig223
Dec 31, 2005 07:58 PM
