Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
HELP - Tires for my 2001 Audi S4
Old Dec 26, 2012 | 11:39 AM
Juliet's Avatar
Default HELP - Tires for my 2001 Audi S4
I am having horrible luck with tires for my 2001 Audi S4. I bought brand new tires from Sam's in July and I have had problem after problem with them. They seem to go flat and won't hold air, you can hear the air coming out the sidewall. This has happened 3 times now since July. It's making me crazy! What tire brand would you all suggest for an Audi S4 with standard 17' rims? I am taking my car to Big O Tires after work.....there are just so many to chose from.....Help......
And what does Load Range mean to me????
Thanks!
Old Dec 27, 2012 | 08:42 AM
lance@tirerack.com's Avatar
Former Sponsor
Hello,
Have you had the wheels inspected? To me it sounds like the tires are not mounting correctly and you are not getting a good seal on the bead. This could be because a wheel is damaged or bent. You should take the S4 to a tire shop that can do a "Run Out" on the wheel. They should be able to tell you if it is the wheel or the tire that is the problem. I truly do not believe it is a tire issue, especially with as many tires as you have went through.
Thanks,
rvdtsunami
Jun 12, 2012 10:28 AM
GillzAudi
Jul 30, 2008 01:34 AM
silverttq
Jul 23, 2008 01:13 PM
hoogaface
25
Sep 19, 2006 05:26 PM
orodrig223
Dec 31, 2005 07:58 PM
