Tires installed
I bought the Kumho Ecsta ASX from Tire Rack - $91each. Working well so far, very good in the corners and very good wet traction too.
Unfortunately the installer scuffed the wheels in a few places. Anyone know if these can be polished out? Also may need to get an alignment as the car pulls to the right now.
Not sure I would recommend this installer.
ive heard good things about these tires from many people. i think i will pick these up next time mine are dead.
sucks about the install though!! i actually just replaced all 4 center caps on my fat 5s because 3 of them had the clearcoat chipping off thanks to certain people prying them off improperly with screwdrivers :\ the winter salt got underneath the clear and made it all come off....
ORIGINAL: kwaskow
I think the clear coat is what this guy scuffed off in a few places....can I recoat them myself?
ORIGINAL: kwaskow
as far as the centercaps go, what happened to mine is that some asshat with a screwdriver chipped into the outer edges to get the caps off, this was done in multiple places around the edges. the chipping caused the clear to completely separate from the metal, going farther and farther into the cap. then the winter salt kicked in and made them even worse. and all the while a crapload of brake dust was creeping under the edges and causing black staining that couldnt be wiped off. finally i just got sick of it and bit the bullet on a new set from the dealer. the new ones look awesome however and made my wheels look almost mint again.
kaptom540
Jan 24, 2008 08:53 PM
pindonesia
Nov 16, 2005 11:43 PM
jmerrell
Aug 25, 2005 04:01 AM
miamitrails
Aug 17, 2005 03:08 PM
