Transmission Fluid
Old Sep 2, 2007 | 04:51 PM
8rings's Avatar
Default Transmission Fluid
While changing the oil yesterday my friend inadvertently dumped the transmission fluid while we doing an oil change. A simple mistake given that the tranny has a drain plug showing right on the bottom of the car in the cover opening. As you all know the oil drain is under the plastic cover.
Well since I didn't intend to change the tranny fluid I have a few questions.
My car is sitting in the garage now undrivable since it has no fluid in it.
What type of fluid do I use? Where to get it?
And where on earth do you fill the tranny, I couldn't see a fill plug anywhere, possibly on the back right (driver side) top corner?
I found info on the manual, but this tranny is the auto tiptronic in the 180FWD.
Thanks for the help.
Old Sep 3, 2007 | 06:26 PM
MeanAudiA6's Avatar
Default RE: Transmission Fluid
i dont know what fluid goes in the automatics....check with Audi...i know on my 6speed the fill plug is right above the drain plug...remember its a fill hole so its not gonna be on the bottom. it should drain out like a waterfall if that helps. 17mm hex i believe is what mine takes. i could look in my bentley manual but at work now.
Old Sep 4, 2007 | 12:03 AM
8rings's Avatar
If you wouldn't mind taking a look in the bentley manual that would be cool. I am familiar with changing tranny fluid but have not on the TT yet. I didn't see a fill plug on it anywhere which was confusing. The drain plug was a 17 hex on the very bottom of the pan, but can't seem to find the fill. Everything I can find on the subject deals with the manual tranny.
Thanks for the help....
Old Sep 4, 2007 | 04:16 PM
MeanAudiA6's Avatar
what engine code?
Old Sep 4, 2007 | 04:27 PM
MeanAudiA6's Avatar
G 055 025 A2 is the fluid and it takes about 7.4 qt...damn thats a lot.Audi > TT > 2000 - 2005
6 Spd. Automatic Transmission 09G
37 - Automatic Transmission - Controls, Housing[/align] ATF, changing or filling up after repairs[/align] [/align][*]Engine switched off. [/ul][/align] [/align][*]Special tools, testers and auxiliary items required [/ul][/align] [/align] [/align][*]Drip tray V.A.G 1306 [/ul][/align] [/align] [/align][*]Filler system V.A.G 1924 [/ul][/align] [/align][*]Protective goggles [/ul][/align] [/align][*]Note: [/ul][/align] [/align][*]Observe all notes and test requirements as for "Checking ATF level". [/ul][/align] [/align] [/align][*]Mount reservoir of ATF filler system V.A.G 1924 as high as possible on vehicle. [/ul][/align] [/align][*]Drive vehicle onto a four column lifting platform or over an assembly pit in order for it to be absolutely horizontal. [/ul][/align] [/align] [/align][*]Remove sound insulation tray (arrows). [/ul][/align] [/align][*]Note: [/ul][/align] [/align][*]Always observe the relevant environmental regulations for disposal. [/ul][/align] [/align][*]The engine must not be started or towed without ATF in the transmission. [/ul][/align] [/align] WARNING! [/align][*]When working close to the radiator, always maintain a certain distance from the fan - danger of injury! [/ul][/align][*]Fan may switch on automatically. [/ul][/align] [/align] [/align][*]Draining ATF [/ul][/align] [/align][*]Place drip tray V.A.G 1306 under transmission. [/ul][/align] [/align] WARNING! [/align]
Wear protective goggles. [/align]
[/align] [/align] [/align][*]Remove drain plug (arrow -B-). [/ul][/align] [/align][*]Allow ATF to drain out. [/ul][/align] [/align][*]Unscrew ATF inspection plug -A-. [/ul][/align] [/align] [/align][*]Unscrew overflow pipe -C- (Allen key, size 5) and allow remaining ATF to drain away. [/ul][/align] [/align] [/align][*]Replace seal on ATF drain plug. [/ul][/align] [/align][*]Screw in ATF drain plug -B-. [/ul][/align] [/align] ATF drain plug to oil pan, M18 39 Nm[/align] [/align] [/align][*]Install overflow pipe -C- (Allen key, size 5). [/ul][/align] [/align] Small oil pipe in oil pan 1 Nm [/align] [/align][*]Filling with ATF [/ul][/align] [/align] [/align][*]Remove filler plug (Torx socket head T55) (arrow). [/ul][/align] [/align][*]Note: [/ul][/align] [/align] [/align][*]The filler plug seal (arrow) must always be replaced. [/ul][/align] [/align] [/align][*]Attach hook of filler system V.A.G 1924 in aperture of filler plug (arrow). [/ul][/align] [/align] [/align][*]Top off ATF with V.A.G 1924 until ATF emerges via overflow pipe (arrow -2-) from inspection aperture. [/ul][/align] [/align][*]Move selector lever to position "P". [/ul][/align] [/align][*]Start engine. [/ul][/align] [/align] [/align][*]Continue to top off ATF with V.A.G 1924 until ATF emerges from inspection hole again. [/ul][/align] [/align][*]Tighten ATF inspection plug. [/ul][/align] [/align][*]With brake pedal depressed and engine running at idling speed, select all selector lever positions "P, R, N, D, S" in sequence (each position should remain selected for a minimum of 3 seconds). [/ul][/align] [/align][*]Move selector lever to position "P". [/ul][/align] [/align][*]Check and top off ATF level => Page AUDI-TT-AT01-37-004-0137-97 [/ul][/align]
MeanAudiA6's Avatar
**** the pictures wont show up
Old Sep 5, 2007 | 12:53 PM
8rings's Avatar
Thanks, I owe you one. That is quite a description. Yeah 7.4qts. that is crazy the engine only takes 4.8 qts. of oil.
Old Sep 5, 2007 | 04:36 PM
MeanAudiA6's Avatar
it looks like the drain hole and the filler hole are the same. you have to shoot the fluid into it. via the special audi tool....or something else that will forcefully put the fluid in there. a grease gun might work from the pics i see but i bet you'll need to buy 8qts cuz your gonna loose some while filling up.
konabiker47
Jan 20, 2009 09:28 PM
