trouble with turbo XS hpbc
Old Feb 4, 2008 | 11:38 PM
  #51
Red_sapphire89's Avatar
Default RE: trouble with turbo XS hpbc
ORIGINAL: tom1222
ORIGINAL: zero388
hmm...I peaked at 18psi with my N75 and my apr 93oct program. Isnt that a little high?
Is that on a tt180? I am boosting around 23 psi with my Revo.
im boosting 22 on my diode and i spent 500 less than you
Old Feb 5, 2008 | 07:13 AM
  #52
eliTTe's Avatar
ORIGINAL: tom1222
ORIGINAL: cincyTT
The BM (haha, pooh), still uses the n75, the one here, no one uses the n75. People are talking about the ports where the vac lines use to go. Plugging them would be blocking off the ports for air or anything to go in or out at.
At least the BM seems to be working whereas this marvel of technology seems to have some bugs to work out
there is nothing that needs to be worked out... my problem was being too generous with the bleed valve...
Old Feb 5, 2008 | 05:06 PM
  #53
zero388's Avatar
The mbc is in and calibrated and it worked fine for one run but it would peak at 11psi. Now it wont go past 10 and once it hits 10 it goes down to 20inhg. I dont know if I am increase the coarse and fine to much or what. WHat could be causing this?
Old Feb 5, 2008 | 05:11 PM
  #54
limp mode?
Old Feb 5, 2008 | 05:12 PM
  #55
cincyTT's Avatar
I'm make believe
probably the same as Lucas, your b&s isnt set enough. You need to open the bleed (colored) 2 turns from closed and the b&s to where the ball doesnt make any more noise + about 1 full turn.
Old Feb 5, 2008 | 05:17 PM
  #56
zero388's Avatar
so basically recalibrate it and go from there?
Old Feb 5, 2008 | 05:23 PM
  #57
cincyTT's Avatar
I'm make believe
Yes. Take it out and follow the directions and then a little more to be safe. It will give you a good starting point
Old Feb 5, 2008 | 05:28 PM
  #58
zero388's Avatar
I did that last time and and I drove the car and it spiked at 7psi then started rasing it and it did the thing in my above post. I dont know what else I can do I have already recalibrated it several times,
Old Feb 5, 2008 | 05:32 PM
  #59
cincyTT's Avatar
I'm make believe
you do have the pressure to the brass fitting correct? The brass side piece is also theball and sping.
Old Feb 5, 2008 | 05:37 PM
  #60
zero388's Avatar
Mine doesnt have a brass fitting but it is the the same side that the brass fitting is on the older ones. SO yes.
