Sway bars ... give me the skinny
Old 02-03-2009, 08:08 PM
Niclipse's Avatar
Default Sway bars ... give me the skinny
In the following article:
http://forums.vwvortex.com/zerothread?id=2858460
The author gives an order of suggested upgrades for the TT and one of them is a mention of rear sway bars only and not the mention of the fronts. Is this on purpose or should I do both the front and rear?
Also, what are the brands/cheapest sites to purchase from?
Old 02-03-2009, 08:14 PM
theTTkid's Avatar
all going to run close in cost, unless you get both front and rear same time. awe-tuning.com i think has both for once.
anywho, if your only going to do 1, do rear. however, front is still a great mod to do, but the install is tedous.
25mm front and 22 rear i think would be the way to go.
right now im sitting on coilovers and will throw in sways as soon as i get the money
Old 02-03-2009, 08:57 PM
cincyTT's Avatar
I'm make believe
People do the rear to reduce understeer and if stiff enough, create overstear.
Old 02-03-2009, 09:16 PM
joshuo's Avatar
The thread mentions the 28mm bar without doing a front.
Wouldn't that create a shedload of off-throttle oversteer?
I always heard if you're doing the back only, use the 19mm.
Old 02-03-2009, 11:45 PM
cincyTT's Avatar
I'm make believe
You guys do realize that you are looking at a MKIV forum which is a 2000+ Jetta and Gti right? FWD cars need a much larger diam swap bar to help eliminate the massive understeer unlike an awd car
mixta
02-05-2010 04:21 PM
jemrey81
12-02-2009 07:57 PM
tdn
03-09-2008 12:58 AM
discostu32
12-19-2007 08:43 PM
Session101
07-24-2006 05:28 AM
Quick Reply: Sway bars ... give me the skinny
