TT Door Panel Component Removal Help
Old May 3, 2008 | 12:43 PM
Hitchr10's Avatar
Default TT Door Panel Component Removal Help
I am in the process of fixing an issue I am having with my door panels (the trim is bubbling up around the window), and I have ran into a little road block. I pulled the panels off the door, but am having trouble trying to figure out how a particular part comes off the panel. In order to fix the problem correctly, I need to be able to access where the trim wraps around the plastic 'backbone' of the door...the problem is that there is a cloth guide thingamagigger the I assume protects water from getting inside the door. Does anyone know how to remove this thing? I'm pretty sure I did a horrible job trying to explain this thing, so maybe the pictures will help... Thanks!
[IMG]local://upfiles/50433/03C6A8185C4545A6A53647440595A58B.jpg[/IMG]
[IMG]local://upfiles/50433/36594DBEA51841E8AE93D093298A72EC.jpg[/IMG]
stenicilyg
Jan 6, 2010 08:04 PM
kjones6039
Aug 25, 2008 01:04 AM
auS4di
Jun 25, 2006 01:51 PM
auS4di
Jun 22, 2006 09:16 PM
sharkbait
Sep 7, 2004 12:17 PM
