TT roadster convertible roof problem
Old Jun 11, 2015 | 12:32 PM
TT2002_Martin's Avatar
Default TT roadster convertible roof problem
Hi guys, I have a problem when i try to open the top in my TT roster, what happens is when I turn the latch lock and press the key the roof is not opening and I have to do it manually. The switch is working because when I press the open side there is a little light turns in my dash so I know the switch is ok and also in order to close the top i can use the switch to close it normally and it works. Does anyone has any idea what is wrong with my car?
Old Jun 22, 2015 | 03:27 PM
Mike K34's Avatar
Default Fix for roof sensor problem
I have this issue as well.
There is a good discussion in another thread on this forum here, with a solution. The link is posted below.
I've attached a picture because it took me a long time to decipher where this switch is. The silver tab becomes bent slightly and a small bend will fix the problem.
https://www.audiforums.com/forum/aud...sensor-109797/
Attached Thumbnails TT roadster convertible roof problem-img_1350-audi-roof-switch-location.jpg
Old Sep 12, 2020 | 01:20 PM
Patrick Heinemeyer's Avatar
Default convertible roof handle removal
hey do any of y'all know what kind of key that is installed inside the roof handle? i'm 90% done with the new roof install, i just need to remove the handle so the panel can go over the mechanism, then i can reinstall it, any tips?
logopolis
Sep 27, 2020 12:05 AM
SuttonFurniture
Jul 28, 2018 11:05 AM
newsrus
B7 Models
Sep 17, 2017 04:06 PM
Arcer
B7 Models
Nov 28, 2011 11:56 PM
astraclub
Jun 2, 2010 04:12 PM
