I keep hearing mixed info on this so I was hoping someone could clear it up. I want to put a air/fuel gauge in my TT225 but I am not sure if it operates on a wide or narrow band O2 sensor. If it is narrow I here it is inaccurate anyway and I should upgrade to a wideband sensor. If it is already wideband can I get just a gauge? The AEM kits I am looking at come with a sensor as well. Can you just tap into the existing wideband (if it is wideband) without installing a new sensor as well? Thanks for you help
RE: TT225 O2 sensor wide or narrow?
An air/fuel gauge is inherently innacurate regardless of whether its a narrow or wideband signal. If you want accuracy you want an EGT gauge. Much more reliable tool for tuning the mixture of your car.
Quote:
ORIGINAL: ravenTT
I've tapped mine directly into the pre-cat O2 sensor wire under the car. It works, albeit the needle swings pretty wildly because the gauge is reading the instantaneous voltage off the sensor.ORIGINAL: ravenTT
Quote:
ORIGINAL: XCLR8TT
Sounds about right. They are OK to be an early warning of a problem, but essentially useless for tuning.ORIGINAL: XCLR8TT
Thanks for the info. This is my first turbocharged car so I wasnt sure. I went from a 2.8 A4 to a VR6 Jetta to finally a TT. With the EGT, when the temp gets too high its running lean correct? What is considered the high point it shouldnt exceed? Thanks guys
