Lean Condition and loss of power, wide-band sensor
Old Aug 16, 2008 | 03:51 PM
agazoo's Avatar
Member
Default Lean Condition and loss of power, wide-band sensor
Hi,
Have a little problem. Tried pretty much everything and used a search but can't find solution.
I have a wide band sensor and according to it im runnning super lean. When cruising, it shows lowest reading, under load starts jumping through the entire band ... Sometime stays within acceptable range.
Boost gauge shows -17 vac when idling, about 20 cruising. I've also lost a good portion of boost. 10psi at best instead of 17-18 as it used to be....
I checked whole vacuum system and couldn't find any leak. No CEL either (rather then test pipe related one),
I have replaced O2 sensor just to be sure as well.
Any ideas ... ?
I am totally confused ...
Old Aug 16, 2008 | 03:58 PM
audikiller09's Avatar
what kind of diverter valve are you using?
Old Aug 16, 2008 | 04:24 PM
agazoo's Avatar
Member
710N, One which goes with TT
vtraudt
Mar 15, 2010 12:12 PM
dragonrage
Oct 2, 2009 12:18 PM
tbonetyler789
May 14, 2009 12:56 AM
agazoo
Feb 25, 2009 04:20 PM
a4intec
Sep 23, 2006 12:00 PM
