Turbo/Mod setup & yielded boost
Old Feb 27, 2007 | 12:03 PM
stephenson27's Avatar
Default Turbo/Mod setup & yielded boost
Last week I chipped my basically stock 2002 180Q (k03s) with GIAC and afterwards noticed that it would hit 18-19lbs of boost but immediatly drop to 14-15lbs. This would repeat three times before it would settle at the lower range. Previously, with the REVO trial the turbo would sustain 18-20 without any problems. With that, I installed a MBC and bypassed the n75. With it tightened all the way in (the lowest amount) I am now running 20-21lbs of boost consistantly. Other than chipping I've installed the better NGK's and a drop in K&N.
I'm wondering what others are running in regards to Turbo/Mod setup and what boost your pushing?
Old Feb 27, 2007 | 01:54 PM
cincyTT's Avatar
I'm make believe
Default RE: Turbo/Mod setup & yielded boost
your boost changed from tuners and they both react differntly with differnt n75's. But the jump and drop isa boost spike, that is about as good as a ko3 can do sometimes. But as you can probably claim a mbc is a more consistant method of regulating boost.
For me see sig.
Old Feb 27, 2007 | 06:35 PM
225tt's Avatar
Be careful running 21psi on a KO3, that thing is making alot of heat at that psi.
Old Feb 27, 2007 | 06:42 PM
cincyTT's Avatar
I'm make believe
its not there for very long, remember its a ko3.There is still plenty of power in that turbo up to 20-22psi and once you get past thatyouare makingmore heat and the only thing to bring down the intake temps would bea water/meth injection in conjuction w/ a nice intercooler.
Old Feb 27, 2007 | 06:44 PM
proxeyed's Avatar
dumb question.. but what about one of those cryo2 or what ever its called, that pumps C02, for intercooler misting.. is it as effective as the water/meth, any advantages or disadvantages?
Old Feb 27, 2007 | 06:52 PM
cincyTT's Avatar
I'm make believe
water/meth injection >co2
there are so many added benifiets from running water meth over co2
increase octane: more boost'/timing
reduced detenation
less cost
and tons more
Old Feb 27, 2007 | 07:04 PM
proxeyed's Avatar
sounds good to me. thanks! sorry to jack the thread.
Old Feb 27, 2007 | 07:05 PM
Remember it's a k03s and from my understanding you can get a little extra out of it. None the less I never runn all out for an extended period of time.
Old Feb 27, 2007 | 08:35 PM
proxeyed's Avatar
lol. KO3s.How do you like the setup though, big difference?
Old Feb 27, 2007 | 11:57 PM
Yeah, it's awesome to say the least! Before, it seemed like no matter what I did the power wasn't there but now it's waiting on demand. My friend at work has a modified MiniS and from 3rd on the interstate he was seeing my tail lights rather quickly. I hope to dyno it sometime next month.
