Turbo Question
Old May 6, 2008 | 12:15 PM
kwaskow's Avatar
Default Turbo Question
1.8L, 225 TT has a rattly sounding Turbo when I let off the gas. Sign of a problem? Does not happen all the time and seems to improve the longer the car is run
Old May 6, 2008 | 01:05 PM
Murderface's Avatar
Default RE: Turbo Question
Do you mean "rattly" as in "fluttery"?
Like a whish-sh-sh-sh-sh sound? if so your diverter valve is busted.
Old May 6, 2008 | 05:02 PM
kwaskow's Avatar
nope - not that.....almost like an exhaust rattle, but only when the turbo backs off.....hack maybe it is a manifold rattle
Old May 7, 2008 | 10:45 AM
cincyTT's Avatar
I'm make believe
check the manifold bolts, the dp bolts and the wastegate nut. Most cases its on of those and just needs tightened
Old May 7, 2008 | 11:43 AM
myslow1's Avatar
heat shield?
Old May 7, 2008 | 11:58 AM
cincyTT's Avatar
I'm make believe
There is a sheild attached to the valve cover but its basically a small lip to prevent heat to the coilpack wires. there is also a heat wrap on the chargepipe but neither would make the noise.
Old May 7, 2008 | 12:11 PM
kwaskow's Avatar
THanks for all the advice.
What is the best repair manual I should own for this vehicle?
Old May 7, 2008 | 12:18 PM
cincyTT's Avatar
I'm make believe
a bentley manual. You can get a book or cd cheapest from amazon. But if you want just graphs and part numbers, vagcom.com. It gives part numbers also.
Old May 7, 2008 | 12:33 PM
myslow1's Avatar
ORIGINAL: cincyTT
psh... maybe his car has one and nobody else does!haha
Old May 7, 2008 | 12:42 PM
kwaskow's Avatar
Has one what?
