Turbo timing question
Old Dec 12, 2005 | 10:35 PM
TTsteve's Avatar
Default Turbo timing question
I wrote to atp turbo about their new high flow manifold and the GT2X and asked this question but Im not sure what the answer means. Here is the question;
Will the manifold give the GT2X more HP, if so how much?
Less timing pulled on the high rpms if you keep the same mapping when
switching from stock to the high flow manifold. Also if you remap for the
higher flowing manifold, you can run a lot more timing advance for a lot more
power.
Im not sure how to interpet the answer, can someone explain the timing in regards to turbos? Thanks.
Oh the GT2X for the 1.8T transverse engine is suppose to be out by X-mas.
Old Dec 23, 2005 | 05:46 PM
RussTT's Avatar
Default RE: Turbo timing question
I think their talking about adjusting the ecu for more power from the manifold.
Of course your gonna gain more significant HP over the stock since its a tubular design manifold. My guess would be 10-20 hp more.
Old Dec 25, 2005 | 01:27 PM
TTsteve's Avatar
So if I replace the manifold along with a new turbo (K04-01 or GT2X) I will get the hp gain from the turbo and another 10 - 20 from the manilfold when I remap the ECU? That should get me tomy goal of 240 - 250 whp even with the K04.
Old Dec 26, 2005 | 05:00 PM
RussTT's Avatar
yeah i would say more towards 10 hp though it wouldent be a huge increase
better flow of air = better efficiency = more hp
Old Dec 27, 2005 | 12:17 AM
TTsteve's Avatar
So what is the 160 thermostate and what does it do?
lyonsd
Sep 21, 2010 09:48 PM
bassperformance2009
Mar 5, 2009 11:16 AM
Jessie2k
Aug 5, 2008 01:39 PM
mosuniq
Jul 6, 2008 01:59 PM
xX|05:A4|Xx
May 3, 2008 08:28 AM
