turboxs hp-bc install and tune
Old Nov 10, 2008 | 02:31 PM
225GUY's Avatar
Default turboxs hp-bc install and tune
Anyone have any tips or how tos for this? I dont want to blow anything up installing it. Also any tips to set it to what everyone else is chipped, around 21-23 psi? Thanks very much.
Old Nov 10, 2008 | 03:50 PM
cincyTT's Avatar
I'm make believe
All you have to do is set it up before install like the directions say to and then just bypass the n75. This will give the mbc full control and you can then set the psi level from there. Just do a few pulls to see where you are at psi wise, pull over, adjust the mbc and do a few more pulls. Keep doing this until you have it setup the way you want it. The ball and spring will make the turbo spool up faster and hold boost longer and the bleed will smooth out the boost onset and spiking. Personally i have the b&s do most of the increase over the wastegate and the bleed increase the last 3-4psi so it doesnt spike and is smooth even with a ko3 and 2.0.
As for psi level, 23-24psi is fine on the 225.
Old Nov 11, 2008 | 12:43 PM
225GUY's Avatar
it says something about turning the side **** until it stops rattling.. i turned it far and shake it and it still rattles. also how do i know which lines to hook up where?
Old Nov 11, 2008 | 12:51 PM
keefboz's Avatar
I had a bad experience with this, mainly because i am impatient. I attached it all properly, but couldn't get the boost over 15psi without it failing. It took a long *** time also to get to this point, going up and down to find the right spot, make sure you have a lot of time available and a nice stretch of road!
i eventually took it off and went back to the n75, i might put it on at a later date... we will see.
Good luck!
Old Nov 11, 2008 | 02:12 PM
225GUY's Avatar
im just not sure of which lines to hook up, i hate to admit it, but dont know where the n75 is.
Old Nov 11, 2008 | 03:47 PM
theTTkid's Avatar
^ dont be ashamed, everyone has to learn at some point... hope this helps
purple is the n75
edit: this is on my 180, idk if its different on a 225 or not
Old Nov 11, 2008 | 03:58 PM
cincyTT's Avatar
I'm make believe
same basic layout. That pic clearly shows the line from the charge piping to the mbc and which side it goes to. I have the older blue version with both sides needing the hex wrench, takes me 5mins to get to the right psi.
To set it up, if you loosen the brass side all the way, you can hear the rattle of the ball. You just slowly turn it till it stops. Should be a good 2-3 full turns. The old style was then also 2 full rotations of the bleed from closed. This basically set me to about 9-10psi and then i went from there
Old Nov 11, 2008 | 04:07 PM
225GUY's Avatar
i did get it to stop rattling. i still dont get which hose goes where. and i should adjust the coarse side first to like 20 psi and then use the fine side to adjust it up to 24psi?
Old Nov 11, 2008 | 05:43 PM
theTTkid's Avatar
youll wanna do a little bit of both...
the pic shows the hoses...
red to blue
green to yellow
Old Nov 11, 2008 | 06:44 PM
cincyTT's Avatar
I'm make believe
Thats about how i have it setup, 3-4psi with the bleed (fine) and the reast with the b&s (course).
The line from the charge pipe will go to the nipple opposite of the brass fitting, the line going done behind the engine to the wastegate will go from the nipple opposite of the top bleed adjustment. You can see the way it is in the pic above.
