turboxs hp-bc install and tune
Old Nov 13, 2008 | 05:00 PM
  #21
keefboz's Avatar
Wow! That sounds like it was done really easily! That same noise you got was what i had when i went over 15psi. It seems like your problem was the DV, I am running with the forge hybrid DV/BOV, maybe i should just run it as a DV?
May try this mod again this weekend depending on the weather.
Old Nov 13, 2008 | 05:33 PM
  #22
cincyTT's Avatar
I'm make believe
^ you may just need more turns on the valve. Mine held 20psi no problem
Old Nov 15, 2008 | 04:08 PM
  #23
bvgoosedd's Avatar
I hope u guys know I'm gonna need help with this on Sunday. I have no clue what u guys are talking about. LOL
Old Nov 15, 2008 | 04:20 PM
  #24
cincyTT's Avatar
I'm make believe
go to turboxs.com and read the instructions and you will
Old Nov 15, 2008 | 05:00 PM
  #25
bvgoosedd's Avatar
wow that looks simple thanks
Old Nov 16, 2008 | 02:50 PM
  #26
bvgoosedd's Avatar
ok i know i'm gonna get screamed at but basicly u replace the lines that go to the n75 with the mbc??? but leave the n75 plugged in.
Old Nov 16, 2008 | 04:10 PM
  #27
keefboz's Avatar
thats right!!!
Old Nov 16, 2008 | 06:16 PM
  #28
bvgoosedd's Avatar
ok guys i need help! So i need to know if you guys have the same problems i'm having? In first and second gear i can't get my boost over 16 in 3rd gear and up i can hit 20 nutthin higher tho? Also when i hit 20 psi my boost always goes back down to like 15psi. now my car has done this before i installed the MBC. i got the turbo xs hpbc. also a forge 004 and also i have revo. Is it normal for me not to be able to get more then 16psi in first and second even with out the mbc. cincy do u have aim. i really need someone that know their stuff.
Old Nov 17, 2008 | 05:16 AM
  #29
theTTkid's Avatar
alright, make sure you have the right spring in your 004... i think it should be the yellow one...
also, first and second your going to see lower boost. 3+ gives you more boost... as for setting everything, you just gotta fine tune it here and there...
even though you asked for cincys im ill give you mine.. audijew.. ive got the turboxs too so i can probably help a little bit
Old Nov 17, 2008 | 08:37 PM
  #30
bvgoosedd's Avatar
thaks ttkid i trid to hit u up on aim bvgoosedd is my screen name. i think i find out what the problem was. i wasn't turnin my car off after each adjustment. don't know if you have to but after i did i was running a solid 20psi out of every gear but 1st and 2nd. def feels better. Thanks all for the help. i would def recomend
Anos
Mar 3, 2008 05:18 PM
kemp_travis
Nov 2, 2007 12:56 PM
TTinNC
Dec 17, 2006 09:14 AM
Dunzie182
Aug 9, 2006 03:57 AM
rummy
Apr 5, 2006 06:34 AM
