turn signal stops after a few blinks
Old Dec 30, 2005 | 06:51 PM
TTsteve's Avatar
Default RE: turn signal stops after a few blinks
I will give it a try, I saw on another site that you have to take the radio out and then take out the hazard switch/relay so I guess I have to go and buy the tool to remove the radio and see how much the part will cost. One guy paid a $100 bucks to have the dealer do it. Way too much, Ill do it myself. Might see if autozone or somebody has the tool I can use as I heard the tool can cost about $30.
Old Dec 30, 2005 | 08:51 PM
AudiTech04's Avatar
Yes you will have to remove the radio
And there is a cover that you have to pull down directley above the radio
Then push out the switch from the back towards yourself
Old Jan 1, 2006 | 10:20 PM
achTTung's Avatar
You can make radio removing tools, either from a old hacksaw blade, or I've seen it done with the metal strips out of a hanging file folder.
Old Mar 24, 2006 | 07:39 PM
mikepangko's Avatar
My turn signals both just stopped working altogether, but prior to there failure they acted the way you describe yours acted. Did you ever get this problem sorted out? Was it the hazard switch? How much did it cost to fix or did you do it yourself?
Thanks!
Old Mar 25, 2006 | 01:25 PM
TTsteve's Avatar
Yes it was the hazard switch and it cost about $80 for the part thu the dealer.
Old May 10, 2006 | 02:20 AM
ruudje's Avatar
any way to order this switch online? our A4's turn signals are stagnant since today. Managed to tinker it by changing the fuses but
now also that option does not give the required result.
assume this would be the right one? Sorry for asking, but I am more careful with my wife's A4 than my own old Benz....
http://replacement.autopartswarehous...witch&dp=false
pls let me know
thks Ruud
Old May 10, 2006 | 12:21 PM
aTiTude's Avatar
quote:
ORIGINAL: AudiTech04
Did either of you happen to read my post
Its the hazard switch
You know its the one above the radio with the triangle on it
That is you problem
Come on man did you read the post
HAHAHAHAHAHAHA! Man that is frustrating!!!! Funny, but frustrating. "Come on man!" HAHAHAHA
Old May 11, 2006 | 04:42 PM
  #18
ruudje's Avatar
tee hee hee[:@][8D]... I am getting the damn part today and this coming weekend will be TOOL TIME! Big fun.
Old May 23, 2006 | 08:32 PM
  #19
305audi's Avatar
I think i am having the same type of problem:
my turn signal will work when it wants to but when my lights are on i can see that the turn signal bulb is lit. Im gussing it is a relay. Am i right?
thx
Old May 23, 2006 | 10:33 PM
  #20
TTsteve's Avatar
Probably so, it cost me about $80 for the part and some more for the install.
