turn signal stops after a few blinks
I have a similar issue with mine where the turn signal studders for a sec and then goes normal then a few seconds later it will go studder again. All my signal lights seem to work and they also studder when the signal does.
You think it could be the turn signal switch?
My signals did the same thing before too but now they just blink a couple of times and then stop. I guess I will find the flasher fuse and replace it and see if that does the trick. I just hope its not real expensive.
ORIGINAL: AudiTech04
Did either of you happen to read my post
Its the hazard switch
You know its the one above the radio with the triangle on it
That is you problem
That is you problem
Thaat sounds about right to me too RussTT, besides I have tried the hazards and they dont stop blinking after a few blinks so Im not sure if the hazards and the blinkers are on the same relay or not. Im just trying to find where the relays are located.
