Urgent help: Window mechanism
Old Nov 27, 2005 | 07:33 AM
stan_the_man's Avatar
Default Urgent help: Window mechanism
Does anyone know how to wind the pulley cable back onto the motor wheel.
I took the motor off and the pulley wheel came off too. I've try on 3 different day to get the cable back on without success.
The car is in bits again with rain approaching....
Please help?
Does the Bentley manual say anything?
Which way does the pulley wheel fit into the holder?, is the concaved part facing the motor or away?
Any help would be great?
I've tiewrapped the spring loader so I have maximum cable length but still can't get it to fit in. There must be a technique??????
Old Nov 27, 2005 | 04:16 PM
AudiTech04's Avatar
Default RE: Urgent help: Window mechanism
Umm yeah that sucks, you should have been a bit more careful when pulling off the window motor
This has never happened to me so i wouldnt be much help, sorry
Old Nov 28, 2005 | 03:53 AM
mastvadz71's Avatar
Member
only solution replace window regulator
Old Nov 29, 2005 | 06:05 AM
dankhound's Avatar
Yeah its a pretty common problem. YOu really have to be carefull taking off the motor because the pully likes to come with it. And once its out its pretty much junk.
Old Nov 30, 2005 | 10:18 PM
steviejayvaughan's Avatar
next time get a flat tip screw driver and pull the motor out a little bit and pop the regulator piece back off the gear. regulator is junk now.
tripppa
B7 Models
May 24, 2013 11:26 PM
Euthanasia
Sep 22, 2008 11:23 AM
eledora
Jun 9, 2008 05:07 AM
alxjhn
Apr 16, 2008 03:27 PM
chaser
Mar 17, 2008 11:27 AM
